When switching to French mode, the logo in the header disappears.
We recommend going to WPML > Settings > Custom Field Translation and setting any theme-related settings fields to
Copy
More details. After this, please translate the templates and pages again.
If this solution does not resolve your issue, or if it seems outdated or irrelevant to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should you need further assistance, please do not hesitate to open a new support ticket at WPML support forum.
Last updated by femi-cleolaV 1 month, 1 week ago.
January 4, 2025 at 9:35 pm #16563854
femi-cleolaV
It's looking/functioning good now -- with one exception:
For some reason, when I enter French mode, the Logo in the header disappears:
Not sure why?!
Mark
January 4, 2025 at 9:37 pm #16563856
It would be very helpful if you could send us the WPML debugging information.
More information here:
https://wpml.org/de/faq/provide-debug-information-faster-support/
January 6, 2025 at 3:47 pm #16566967
femi-cleolaV
Thanks! Debug info attached above.
January 7, 2025 at 1:09 pm #16569587
It looks like you are using a custom theme and the issue might be related to this theme.
I would like to offer to take a closer look into this issue and request temporary access (wp-admin and FTP) to the site to investigate the issue further.
IMPORTANT
Video:
January 7, 2025 at 2:11 pm #16570006
femi-cleolaV
Thanks, but our WP admin pages are locked down such that only local admins on our enterprise network have access.
Any idea what I should look for, something in our theme that might be breaking this?
Maybe a Setting (see attached image)?
Much appreciated,
Mark
January 7, 2025 at 3:00 pm #16570357
Yes, I would suggest to set any setting related fields to "Copy".
Then translate the templates and pages again.
January 7, 2025 at 5:43 pm #16571012
femi-cleolaV
All issues resolved:
Many thanks,
Mark
