Home›Support›English Support›[Waiting for user confirmation] Split: some products were translated successfully but not displayed correctly on the front end
I translated all the products, but some products were translated successfully but not displayed correctly on the front end. Also, the "color" on the single product page could not be translated correctly.
In the Advanced Translation Editor, I could see that this hidden link">product is not fully translated into Chinese. So I completed its translation. Then I could also find "color" in the admin strings section and translated it in Strings Translation. Now the product is translated. Please see the attached screenshots.
Could you please confirm that this issue is now resolved?
Yes, I saw that "Chinese" has been successfully translated. I tried to translate other languages, but it still cannot be displayed correctly when opened in the front-end browser. Where is the location of this advanced translator? How can I find its location?
The Advanced Translation Editor is what you get when you translate a product, a page, or a post. In any case, this is not relevant to the 'color' issue. To correct the 'color' issue, please follow these steps.
1. Go to WPML -> Taxonomy Translation.
2. Select 'Product color'.
3. Scroll down to the Translations of taxonomy color labels and slug section.
4. Translate the name 'color' into each language.
Please see the attached screenshot. I tried it in French and it worked. Please see the attached screenshot.
My name is Carlos, and I will continue working on this ticket while my colleague Itamar is on vacation.
Unfortunately, we can't translate the content for you because it falls outside of the scope of our support service. If you have any specific doubts, we are happy to clarify them for you.
I recommend you consider whether the automatic translation helps you save time and energy translating the content, therefore avoiding this problem in the first place: https://wpml.org/documentation/automatic-translation/
You can see that Itamar has helped me solve the problem, but when I follow Itamar's method, the front end cannot be displayed correctly, so I need to know why this happens. If you don't know the reason, I will continue to wait for Itamar to answer my question.
Please follow these steps:
- Take a product as a reference
- Edit the selected product in the original language -> Make a small change to the content -> Save the changes
- Go to WPML -> Translation Management -> Select the product and assign it to yourself for translation
- Go to WPML -> Translations -> Take the product and update the translation (make sure the translation is 100%)
- Double-check if the issue has disappeared
Can you tell me the results of the steps described above?
I followed your instructions, edited the product, modified some of the content, and updated the translation, but after refreshing, it still does not display correctly.
Could you please follow the solutions Itamar gave me and check them? I think Itamar's solution is correct, you can see that he helped me translate successfully before.
If you follow the steps Itamar described and you mentioned in your previous message, what is the result? Also, can you tell me why you aren't following these steps?
