You noticed that the Italian language was translated with DeepL and is not available with the WPML AI engine, even though the language mappings show it should be possible.
We explain that this issue arises because German is your site's default language. Currently, the WPML AI engine only supports translations from English to German and Italian and vice versa. It does not support translating from German to Italian directly. To resolve this, we recommend enabling another translation engine like DeepL, which can handle translations from German to Italian.
Please note that this solution might be outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket at WPML support forum.
Last updated by Itamar 1 year, 3 months ago.
Assisted by: Itamar.
January 12, 2025 at 7:38 am #16585170
gabrielR-4
What I also noticed in the export: the italian language was translated with deepl and is also not available with WPML AI even though the language mappings show it should be possible. See screenshots.
January 12, 2025 at 7:44 pm #16586385
Itamar
WPML Supporter since 02/2016
Languages: Hebrew (עברית )
I'm consulting our second-tier supporters about this problem. I'll keep you updated here once I have their reply.
I appreciate your patience.
Itamar.
January 21, 2025 at 10:38 am #16617796
Itamar
According to our tests, this issue with the Italain language not being mapped with the WPML AI engine will be solved in the next version of WPML. We tested this on a sandbox site with the beta version of WPML - 4.7.0-b.1. You can also check our sandbox site by using this link.
(With this link, you'll be directly logged in.)
To validate this, our second-tier supporters suggested I install the WP STAGING plugin on your site. This will enable us to quickly create a staging site and test if the issue is solved on your site with the next version of WPML. For this, we need your permission to install the WP STAGING plugin. Do you allow us to proceed?
Alternatively, if you already have a staging site where we can test this, please share the access details with us and allow us to proceed with replacing WPML with the 4.7 beta version. I'm enabling a private message for the following reply.
Itamar.
January 21, 2025 at 10:43 am #16617849
gabrielR-4
Hi Itamar,
thank you, you may proceed with installing WP Staging and testing it.
January 23, 2025 at 4:12 pm #16629053
Itamar
Unfortunately, the problem persists also on the staging site. I need to escalate this issue to our second-tier supporters. Please allow me to take a copy of your site. I must install a plugin like Duplicator or All In One Migration for this. Please let me know if you agree.
Itamar.
January 23, 2025 at 4:25 pm #16629068
gabrielR-4
Hi Itamar,
you may take a copy for further debugging / fixing, thank you.
January 26, 2025 at 5:14 pm #16635457
Itamar
I took a copy of your site and escalated this issue to our second-tier supporters.
I'll keep you updated on nay news regarding this issue.
Itamar.
January 28, 2025 at 4:33 pm #16643293
Itamar
Our second-tier supporter explains that the message about Italian shows because German is your site's default language. So, with the WPML AI engine, it is only possible to translate from English into German and Italain and vice versa. But, with the WPML AI engine, you can't translate German into Italian. The second-tier supporter says this message will disappear if you enable another translation engine like DeepL.
Itamar.
