The client was unable to translate a string on their website, and some methods were deprecated in the admin interface. The main issue was that the English header was not displaying correctly, showing a Persian header instead.
We identified that the issue was related to the use of a legacy widget that was no longer compatible. To resolve this, we guided the client to make corrections in the widget settings. We provided a direct link to the widget settings page and instructed the client to adjust the widget language each time edits were made. After making these adjustments, the issue with the string translation was resolved.
If this solution does not resolve your issue, or if it seems outdated or irrelevant to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket.
Last updated by Kor 3 months ago.
November 15, 2024 at 7:38 pm #16409596
sinohehE
No really,
It always shows a wrong one in one language or adds more to one or use wrong translation
November 15, 2024 at 8:24 pm #16409723
Thanks for your reply.
It looks like you've made some edits. Could you tell me which one is incorrect? I can correct it for you. The issue is due to the legacy widget which is no longer compatible. I need to correct the widget language every time I make edits.
November 15, 2024 at 8:27 pm #16409727
sinohehE
Which table should I edit, I’ll do by my own
November 15, 2024 at 8:29 pm #16409729
You can correct it here first as shown in the attached screenshot. hidden link
If it shows multiple widgets on a language, let me know and I will correct it.
November 15, 2024 at 8:59 pm #16409828
sinohehE
When you visit the frontpage, all texts should be in the same language as the selected one , all of them
November 15, 2024 at 9:52 pm #16409889
sinohehE
English and French are correct but as you can see the Persian has incorrect translation
November 16, 2024 at 6:51 am #16410239
Could you recheck now? thanks
November 16, 2024 at 3:11 pm #16410856
sinohehE
Perfecto, I'll not touch this widget ever 🙂
I do appreciate your time and effort.
November 16, 2024 at 6:10 pm #16411069
Glad that helped. Closing this ticket.
