 jeffreyB-17
NOT working (Out of Stock):
Working (In Stock):
 Carlos Rojas
WPML Supporter since 03/2017
Languages:
English (English )
Spanish (Español )
Timezone:
Europe/Madrid (GMT+02:00)
Thank you for sharing the links.
While I compare the products I kindly ask you to increase the max_input_vars as described in the warning in this page: hidden link
 Carlos Rojas
Languages:
English (English )
Spanish (Español )
Timezone:
After re-saving the English version of this product: hidden link, it looks correct now. However, the other two products are still showing out of stock. Can you create a staging site with a copy of the production site so we can run further tests?
I have set your next message private so you can securely share the access credentials to the staging site.
 jeffreyB-17
I can't make a staging site because it's 3GB and it will take too long. What did you do with the hidden link product? Because then that's the step to fix it for the other two products left as well.
 Carlos Rojas
Languages:
English (English )
Spanish (Español )
Timezone:
I edited the product in English and clicked 'Save'.
Can you describe the steps you followed to translate the products? Because when I edited the product in English, I didn't see the expected warning pop-up window.
 jeffreyB-17
I just translated everything automatically when getting the shop online and then had to publish everything.
But do you know how to fix this or not? If not, please connect me to someone a rank further who knows more about technical difficulties. I can't be messaging back and forth all day for such a small problem.
I'm sorry, I don't mean to be rude but I just want it to be fixed and it doesn't seem to be fixed this way.
 Carlos Rojas
Languages:
English (English )
Spanish (Español )
Timezone:
While the issue is solved on some products after re-saving them, others stay out of stock. I have escalated this ticket to our 2nd tier of support so our 2nd tier specialists can take a deeper look.
I will get back to you as soon as I get more information.
Thank you for your patience and understanding!
 Carlos Rojas
Languages:
English (English )
Spanish (Español )
Timezone:
The WooCommerce Wholesale Prices and WooCommerce Wholesale Prices Premium plugins cause the issue. If you deactivate them, the problem disappears.
Our 2nd tier specialists recommend setting the 'wwpp_product_wholesale_visibility_filter' custom field to 'Copy'. You can do this in WPML -> Settings -> Custom Fields Translation section.
Can you confirm that the issue is solved?
 jeffreyB-17
Hey Carlos, the issue is solved! Thanks you very much!
 Carlos Rojas
Languages:
English (English )
Spanish (Español )
Timezone:
Hey, I'm happy to hear that the issue is solved 🙂
Please don't hesitate to contact us if you need our help in the future with WPML.
Have an excellent day!
