You are using WPML for automatic translations in WordPress with the Avada theme and have encountered an issue where the translation for product variations does not work from Dutch (NL) to English (EN). The variations are locked, making it impossible to set them manually. This issue arose after manually changing the variables for one item.
We recommend using global attributes and translating them.
If this solution does not apply to your case, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should these steps not resolve the issue, please do not hesitate to open a new support ticket with us at WPML support forum.
No supporters are available to work today on this forum. Feel free to create tickets and we will handle it as soon as we are online. Thank you for your understanding.
Last updated by Osama Mersal 2 months ago.
Assisted by: Osama Mersal.
This ticket is now closed. If you're a WPML client and need related help, please open a new support ticket.
