When attempting to translate a product using WPML, two issues occur: 1) slug translation is not available, and 2) every other attempt results in only code translation being available, not visual.
The issue is identified in the file
plugins/woocommerce-multilingual/inc/translation-editor/class-wcml-editor-ui-wysiwyg-field.php
. It involves a function that loads translation jobs, which interacts with another process in WPML, causing the problem. A temporary workaround involves commenting out specific lines in the mentioned file to prevent the issue. However, our developers have currently decided not to permanently fix this issue due to past complications with the wpautop function. If more reports arise, they may reconsider.
If this solution does not resolve your issue or seems outdated, please check the related known issues, verify the version of the permanent fix, and confirm that you have installed the latest versions of themes and plugins. We highly recommend opening a new support ticket for further assistance at WPML support forum.
This topic contains 26 replies, has 2 voices.
Last updated by Marcel 11 months ago.
Assisted by: Marcel.
September 22, 2024 at 4:58 pm #16206503 | |
alinam-2 |
September 23, 2024 at 9:05 am #16208038 | |
Marcel Supporter
Languages: English (English ) Spanish (Español ) German (Deutsch ) Timezone: Europe/Madrid (GMT+02:00) |
Hi, do you use our Classic Translation Editor or Advanced Translation Editor? Can you please add a screenshot of the code part you see? Best Regards, |
September 23, 2024 at 12:40 pm #16209669 | |
alinam-2 |
Hi, |
September 23, 2024 at 12:41 pm #16209715 | |
alinam-2 |
PS: this also happens even if all plugins -but woocommerce and WMPL - are deactivated. |
September 23, 2024 at 3:41 pm #16210658 | |
Marcel Supporter
Hi, regarding the "Visual" mode, you can try the workarounds mentioned on: https://wpml.org/errata/visual-tab-in-classic-translation-editor-is-not-showing-contents-after-update-to-wordpress-5-6/. There is an old bug with the WP TinyMCE component. Best Regards, |
September 23, 2024 at 6:08 pm #16211374 | |
alinam-2 |
Hi, So, I just tried.= 5. No effect. not sure that the issue is from TinyMCE ... seems more to be WPML's Attached, an image with the original text / code of a given product. It's "normal". If I look at the version to be translated in WPML it's different. There are <p> </p> added .... which are not in original version. TinyMCE doesn't work with blocks. And last, the slug is not proposed for transalation. So, the 2 issues remain Waiting for your feedback Kind regards |
September 24, 2024 at 10:06 am #16213697 | |
Marcel Supporter
Hi, The issue you're encountering is related to a bug in WordPress Core, not WPML. Like many other plugins, we use the TinyMCE editor, which is still included in WordPress even if you're using blocks. Other plugins also rely on this editor. Our suggested workarounds aim to bypass this core issue. If you need further assistance, I recommend posting your issue in the WordPress core ticket: https://core.trac.wordpress.org/ticket/53644 or trying the last workaround mentioned there by one of our own developers. You can also find numerous reports about this issue hidden link">here. Regarding the slug: You can see an example of this setup hidden link">here (hidden link">Login to Sandbox) Best Regards |
September 24, 2024 at 12:11 pm #16214572 | |
alinam-2 |
Hi, |
September 24, 2024 at 12:25 pm #16214733 | |
Marcel Supporter
Hi, I'm talking about the "Visual" Mode not showing anything, and that's a caused by an unsolved WP core ticket. If you are getting p Tags added, please provide me with an isolated staging environment where only WPML, WooCommerce and WooCommerce Multilingual are active so we can isolate and reproduce the issue. Please also try first to increase your WP_MEMORY_LIMIT to min. 128MB, as your setup is running below system requirements for WPML and WooCommerce (not PHP_Memory, that's enough bot your WP_MEMORY_LIMIT defined as constant in WP_MEMORY_LIMIT) Best Regards |
September 24, 2024 at 10:03 pm #16217694 | |
alinam-2 |
Hello, I changed the wp-memory limit to 128. No effect. What is logical since I never got memory exhausted or whatever like this. Now, fact is that visual translator works ca every 2 times. So, it's not always, and it's not never. How could you relate this to "an unsolved WP core ticket", which is 3 years old, while the problem I am reporting is recent. I think since WPML included a wordpress translator. Re. the p tags, sometimes there are present, sometimes not. And anyway, they are never in original product (in WC), they are only in WPML translator. So, logically, they can't be added by WP / WC, only by WPML, you have the facts. For you, there is no relationship between the 2 events. It's a guess without fact. Finally, I have a staging site, which you can use freely. Give me a way to add the credentials |
September 25, 2024 at 5:47 am #16218106 | |
alinam-2 |
ps: your slug proposition does not work No slug translation is proposed in classic editor in spite of the change. |
September 25, 2024 at 5:50 am #16218107 | |
alinam-2 |
sorry, slug translation works now. |
September 25, 2024 at 12:22 pm #16220282 | |
Marcel Supporter
Hi, the next answer is marked as private for the credentials. Best Regards, |
September 25, 2024 at 5:03 pm #16221993 | |
Marcel Supporter
Hi, the provided credentials are not working to access the Web-Auth protecting the Backend. Could you please check them? Thank You! Best Regards, |
September 26, 2024 at 5:40 pm #16227031 | |
Marcel Supporter
Thanks for the access.
The site currently requires a minimum of 141MB of memory. You can view the current usage here. Please note that this increased memory requirement is not only due to WPML but also required by plugins like WooCommerce. Regarding the p Tags:
From what I can see, when you open a product like hidden link">this one, you can see the <p> tag in the "Contenu / Description" field. It disappears when you switch between "Visual" and "Text" modes. I can reproduce this behavior on every page refresh. I will check the database and get back to you. Regarding the "Visual Mode" Best Regards, |
