Supporter timezone: America/Los_Angeles (GMT-08:00)
Last updated by Bobby 3 weeks, 6 days ago.
Assisted by: Bobby.
December 4, 2024 at 5:51 pm #16478277
giorgiK-5
I am experiencing a significant slowdown on my website hidden link when the WPML plugin is activated. I have installed Code Profiler Pro to analyze the issue.
The page load time increases by 2 to 2.5 seconds when WPML is enabled.
Could you please assist with the slowdown issue caused by WPML?
December 6, 2024 at 10:52 am #16485511
Waqas Bin Hasan
Thank you for contacting the support. Meanwhile this ticket is attended by one of my colleagues, I'll recommend considering the followings:
- Consider disabling "display as translated" (Fallback mode) from post types, taxonomies, custom fields, etc. in WPML > Settings.
- Try disabling the setting to "Adjust IDs for multilingual functionality" at WPML > Languages > Make themes work multilingual. Recommended themes should not need this setting.
- Turn off “Track where strings appear on the site” in String Translation.
- Remove strings that are not needed and untranslated strings. You can do this by going to WPML -> Support -> Troubleshooting and scroll down almost to the 3 quarter of page and click "Clear invalid strings" button. This 'll take you to a page with a list of such strings. You can remove this to reduce the load of strings translations.
- You can also try other troubleshooting options like "Cleanup and optimize string tables", "Clear invalid strings" and "Remove ghost entries from WPML tables".
- Do not use any kind of SSL-helping plugins. They produce significant overhead by redirecting every request. To use https properly, just convert all links in the database using a safe search-replace plugin such as Better Search Replace or via WP-CLI.
These are few initial steps you can check and see if these help improving the situation. Please feel free to share your findings and we'll try our best to help you further on the matter.
Regards.
December 13, 2024 at 6:18 am #16509935
giorgiK-5
Thanks for your help. But i already tried all your above suggestions.
December 14, 2024 at 12:31 am #16512881
Bobby
Timezone: America/Los_Angeles (GMT-08:00)
I often use the Duplicator plugin for this purpose: http://wordpress.org/plugins/duplicator/
Thank you,
Bobby
December 24, 2024 at 6:30 pm #16544433
Bobby
WPML settings are correctly set up to prevent additional resource usage and increase performance.
I have also ran the WPML troubleshooting actions and optimized the database tables from WPML->Support->Troubleshooting.
Up to 20% (approx) time increase is normal and expected which is what I am seeing at the moment for both the backend and front end when I compare with WPML activated vs WPML deactivated.
2.80s loading speed with Default Theme + WPML + WPML add-ons + WooCommerce base plugin activated.
5.43s loading speed with Electro Child + WPML + WPML add-ons + WooCommerce base plugin activated.
Activating Electro Child increases loading speed by 93.93%.
As a test please go to Themes and switch from electro to a standard theme such as Twenty25 and let me know your results.
NOTE: We recommend doing these tests on a staging site where the issue has been reproduced if you perform on a live site please make sure you have a recent and working backup available.
The topic ‘[Closed] Website speed’ is closed to new replies.
