I saw it fixed the issue but there is an issue with the site.
On this URL or other urls as well hidden link
When you jump from english to japanese, and return to english, it will display an internal server error. Can you check this and see what causing the issue?
I check the debug log on your site but don't see any fatal error message when the 500 error appears. I suggest you enable a minimal environment as below and see if it helps:
- Deactivate all plugins except WPML plugins and WooCommerce
- Switch to a standard theme of WordPress
If the issue persists, please get in touch with your hosting support and ask them to check the server log if they find any error when switching language on the product page.
It is still an error and this is the error log on server level
[core:error [pid 425092:tid 139710663755520 [client 136.158.24.18:0 AH00124: Request exceeded the limit of 10 internal redirects due to probable configuration error. Use 'LimitInternalRecursion' to increase the li............e., referer: hidden link
It seems like whenever we go a translation product, it causes an infinite loop redirect. Is there a way that the product URL will not change to arabic and stay with english? That might fix the issue
