Related documentation:
This topic contains 22 replies, has 2 voices.
Last updated by Carlos Rojas 1 year, 6 months ago.
Assisted by: Carlos Rojas.
January 3, 2024 at 10:00 am #15145712 | |
Carlos Rojas WPML Supporter since 03/2017
Languages: English (English ) Spanish (Español ) Timezone: Europe/Madrid (GMT+02:00) |
Hi, I tried accessing the site via FTP but it failed. Could you double-check the FTP credentials? |
January 3, 2024 at 10:04 am #15145751 | |
riccardoM-7 |
I just checked and it worked for me. Can you please re-try to connect through SFTP and use only the IP (without the /directory)? |
January 3, 2024 at 10:18 am #15145917 | |
Perfect! it worked with SFTP. I will take a look at the configuration and I will get back to you as soon as I get more information. |
January 3, 2024 at 12:40 pm #15146491 | |
Hi Riccardo, I ran some tests and added the workaround in the errata page (I shared earlier), but the issue persists. We need to check if this issue persists in a minimal setup. For this reason, I kindly ask you to follow these steps: Could you tell me the results of the steps described above? |
January 3, 2024 at 1:31 pm #15146835 | |
riccardoM-7 |
Hello Carlos Thanks for your efforts in this matter. Please see: hidden link hidden link As you can see the same error still persists. The theme is now a default WP theme and all plugins expect for WooCommerce and WPML have been deactivated. The English version of the product still displays "This product is currently out of stock and unavailable." |
January 4, 2024 at 7:31 am #15149401 | |
Hi there, I have created a new test product and the issue disappeared: hidden link This result indicates that the entry in the database for the products with this issue might be corrupted. If you create a new test product in the live site and translate it, does the issue persists? |
January 4, 2024 at 12:32 pm #15150501 | |
riccardoM-7 |
Thanks for your reply. After years of working with WP and WPML, we have come to the conclusion that we cannot continue to operate the store in this way. What WPML offers may have been up to date 10 years ago. In the meantime, it seems to be nothing more than a tinkering of bug fixes and workarounds that generate errors that cannot be logically explained. WMPL is unfortunately miles away from being a plugin for professional users. Please don't take this as a criticism of your support, because it has been excellent and I am grateful. However, this is not the first time that we have spent hours with this tool and we have reached a point where frustration prevails. We will therefore probably rebuild and operate our store via Shopify. |
January 5, 2024 at 8:30 am #15153477 | |
Hi Riccardo, I asked you to run all these steps because I have a strong suspicion that this issue is on a database level. If you authorize me, I can create a copy of the site and escalate this ticket to our 2nd tier of support where (with all the information gathered) our specialists can take a deeper look at this issue and try to find its cause, and therefore a solution. Looking forward to your message. |
