Supporter timezone: Europe/Tirane (GMT+02:00)
Last updated by Marsel Nikolli 1 year, 9 months ago.
Assisted by: Marsel Nikolli.
March 15, 2024 at 10:26 am #15413831
LukaszM-21
I am trying to figure it out what's wrong. I would like to have a few sitemaps per language, not just one mail with all urls.
So far I have updated my function.php:
add_filter('wpseo_posts_join', 'sitemap_per_language', 10, 2);
function sitemap_per_language($join, $type) {
global $wpdb, $sitepress;
if (isset($sitepress)) {
$lang = $sitepress->get_current_language();
return " JOIN " . $wpdb->prefix . "icl_translations ON element_id = ID AND element_type = 'post_$type' AND language_code = '$lang'";
return $join;
results:
*/sitemap_index.xml works
*/lang/sitemap_index.xml 404
when turn off WPML SEO
*/lang/sitemap_index.xml works
there is something with WPML SEO addon that effect it.
March 15, 2024 at 11:32 am #15414089
Marsel Nikolli
Thank you for contacting WPML Support, I will gladly help you.
When reviewing your sitemap I can see it's showing for ES and PL
However, that is not the expected behavior.
Your sitemap should show all languages under 1 sitemap, the only time you should get a different sitemap per language is if you are using a different domain per language.
https://wpml.org/documentation/plugins-compatibility/using-wordpress-seo-with-wpml/#translate-sitemaps
See our sitemap here as an example:
https://wpml.org/page-sitemap.xml
I suggest verifying you are using the latest versions of Yoast SEO, WPML, and WPML SEO
Then do a manual sitemap update, by disabling the sitemap feature, clearing the cache, and enabling the sitemap feature to force the sitemap to rebuild.
Regarding the code you provided, please note that custom coding is beyond the scope of this support forum, we recommend that you check our contractors' page: https://wpml.org/contractors/.
Thank you for understanding and I hope you find this information helpful.
Let me know if you have any more questions.
Kind regards,
Marsel
The topic ‘[Closed] WPML SEO addon blocks sitemap per language’ is closed to new replies.
