If you're using
apply_filters('wpml_copy_post_to_language')
to create translations of products and find that it does not copy product attributes, you might encounter difficulties in achieving complete product translations.
First, ensure that in WPML > Settings, under Taxonomy translation, the translation preference for Attributes is set to "Copy". If this does not resolve the issue, you can manually copy product attributes using custom code. Here's a step-by-step guide:
1. Create an independent translation of the post in the target language using
$translated_post_id = apply_filters('wpml_copy_post_to_language', $product->get_id(), $target_language, false);
2. Retrieve the translated product with
$translated_product = wc_get_product($translated_post_id);
3. Get attributes from the original product with
$attributes = $product->get_attributes();
4. Set these attributes to the translated product with
$translated_product->set_attributes($attributes);
5. Save the translated product with
$translated_product->save();
If you need further customization, consider hiring a developer from WPML Contractors.
Please note that this solution might be outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket at WPML Support Forum.
Our next available supporter will start replying to tickets in about 5.54 hours from now. Thank you for your understanding.
Last updated by Prosenjit Barman 1 month ago.
This ticket is now closed. If you're a WPML client and need related help, please open a new support ticket.
