I am building a WP theme in Spanish and the default language of the site is Spanish, but some strings added to the code in Spanish are showing the source language as English in WPML > String Translation.
This happens because the string was added to the code in a language other than English, you can change the source language of the strings in WPML > String Translation by selecting the string then clicking the "Change language of selected strings" button.
Relevant Documentation:
https://wpml.org/documentation/getting-started-guide/string-translation/how-to-change-the-source-language-of-strings/
Last updated by Ferran 1 year, 5 months ago.
Assisted by: Mohamed Sayed.
May 26, 2023 at 11:03 am #13722517
Ferran
I am building a WP theme in spanish and I've already set up the whole WP environment and WPML default language in spanish, so I am adding the php code like so in, for instance, the template-home.php file:
<p><?php esc_html_e( 'Aprende español', 'BHS' ); ?></p>
(which means 'Learn Spanish')
then I go to the backoffice > WPML > themes and plugins location
to find all the strings and after that I go to STRING TRANSLATION
but I am seeing the flags in the wrong position (please find a screenshot attached)
Maybe I am doing something wrong or I forgot to define or declare something?
or it is mandatory to add the texts in the code only in english?
No
No
it is a local site using MAMP
May 26, 2023 at 6:07 pm #13724909
Mohamed Sayed
Hi Ferran,
Thanks for contacting WPML support, I will be glad to help you.
This happens because the string was added to the code in a language other than English, you just need to change the source language of the strings in WPML > String Translation as mentioned here: https://wpml.org/documentation/getting-started-guide/string-translation/how-to-change-the-source-language-of-strings/
Mohamed
