Last updated by Long Nguyen 1 year ago.
Assisted by: Long Nguyen.
July 3, 2024 at 2:09 am #15879017
Long Nguyen
WPML Supporter since 02/2022
It doesn't mean we will abandon the plugin WPML All Import, it will still be supported along with the new plugin WPML Export & Import. Just the difference is the plugin WPML All Import only works with the plugin WP All Import while WPML Export & Import can work with other import plugins.
It had todo with using the new import export plugin and the new variables for translation groups. Due to a mistake the translation group custom field was set the same for all variations of a variable product.
If the issue is related to the plugin WPML Export & Import, can you please help me replicate the issue in order to escalate it to our development team? I believe it can be replicated with a few products. Please share the import file and steps you do to import products to see the issue.
If you want to test on a site that has MariaDB database engine, please get the site information in the private reply below.
Or on a new sandbox site if you prefer hidden link
Thanks for your co-operation.
The topic ‘[Closed] Wrongly translated Product Variants in secondary lang order viewed in primary’ is closed to new replies.
