The client reported that the product is translated but does not display correctly in various languages, specifically mentioning that variation products are not displayed correctly in the frontend.
We recommended the client to edit the product in the original language (Portuguese), make a small change to the content, save it, update the translation products, and recheck the issue. When this did not resolve the issue, we proceeded to fix it by navigating to WooCommerce > WooCommerce Multilingual > Settings > Troubleshooting, selecting "Sync products variations" and clicking on Start. This process might take some time to complete.
If this solution does not resolve your issue, or if it seems outdated or irrelevant to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Additionally, you can open a new support ticket for further assistance at WPML support forum.
Last updated by Long Nguyen 4 months, 1 week ago.
Assisted by: Long Nguyen.
September 19, 2024 at 8:00 am
rodrigoO-4
The product is translated but does not appear correctly in the various languages.
September 19, 2024 at 9:10 am
September 19, 2024 at 9:11 am #16197406
Long Nguyen
Here is the forum ticket. Let me know the result after you enable the minimal environment as suggested.
September 19, 2024 at 10:07 am #16197671
rodrigoO-4
Staging Site: hidden link
September 20, 2024 at 1:32 am #16201017
Long Nguyen
Did you try to enable the minimal environment as I suggested? Also, please share the staging site credentials in the next reply (the production site credentials were removed for security reasons).
September 20, 2024 at 10:17 am
September 20, 2024 at 3:42 pm #16203708
Long Nguyen
I fixed the issue on your site by going to WooCommerce > WooCommerce Multilingual > Settings > Troubleshooting > Select "Sync products variations" and click on Start (it would take time to complete the process).
Let me know if it works on your end.
Fantasia gerippte Socken mit Kaschmir für Männer | PEDEMEIA® 2024-09-20 22-40-48.jpg
September 23, 2024 at 4:36 pm #16210998
rodrigoO-4
For this product, after carrying out this procedure, it worked. However, for this product (hidden link), even doing this procedure doesn't resolve it.
September 24, 2024 at 1:35 am #16212162
Long Nguyen
You can also try to edit the product in the Portuguese language > Make a small change to the product description > Save > Update the translation product and see if it helps.
On the staging site, I see the variations of that product displayed correctly in second languages
If it does not help, I would like to request temporary access (wp-admin and FTP) to your production site so I can take a better look at the issue. Your next reply is set to private to share the info.
September 24, 2024 at 8:37 am
September 24, 2024 at 12:31 pm #16214747
Long Nguyen
After running the troubleshooting step "Sync products variations" as I mentioned above, the variations in the second languages are displayed correctly. Please recheck this and let me know how it goes.
Pflegeleichte, gerippte Socken aus Merinowolle mit hohem Beinausschnitt für Damen | PEDEMEIA® 2024-09-24 19-28-58.jpg
