- | 10:00 – 17:00 | 10:00 – 17:00 | 10:00 – 17:00 | 10:00 – 17:00 | 10:00 – 17:00 | - |
- | 18:00 – 19:00 | 18:00 – 19:00 | 18:00 – 19:00 | 18:00 – 19:00 | 18:00 – 19:00 | - |
Last updated by Shekhar Bhandari 1 month, 2 weeks ago.
December 14, 2024 at 11:08 am #16513346 | |
fadiS-3 |
Background of the issue: this is a screencast of the issue: hidden link Symptoms: Questions: |
December 17, 2024 at 5:16 am #16519715 | |
Shekhar Bhandari Supporter
Languages: English (English ) Timezone: Asia/Kathmandu (GMT+05:45) |
Hello there, Thank you for contacting WPML support. I'd be happy to assist you on this issue. Can you send me the product csv file in the next private reply so I can test it on my local setup first and see if it works. I have enabled the private reply for you. Look forward to your reply. Thanks |
December 17, 2024 at 7:22 am #16519881 | |
Hello there, For me it works without any issue, can you please do the following and see if it helps: - While Importing the CSV set the ID and SKU to "DO NOT EXPORT". Look forward to your reply. Thanks |
December 17, 2024 at 11:09 am #16521207 | |
fadiS-3 |
ok let me check it out now. But quick question, if i dont import the id and sku, how would i sync the english and arabic products toghether. There are almost 600 products tha i would need to import as a final file |
December 17, 2024 at 11:12 am #16521216 | |
**Hello,** The synchronization will be based on the `_wpml_` fields in the CSV. If you need to use specific SKUs, I recommend using unique SKUs for each field. When WPML imports the data, it will adjust the SKUs accordingly so they remain consistent across all languages. Thank you! |
December 17, 2024 at 11:55 am #16521487 | |
fadiS-3 |
Thanks for this, and sorry im a bit lost here. would you pls be able to create a quick loom video explaining how this would be done, because in the documentation, i learned that the sku's need to be the same for english and arabic which we will then use for _wpml_ translation group field. |
December 18, 2024 at 4:32 am #16524038 | |
Hi there, Were you able to import it using the settings I mentioned? Essentially, the SKU needs to be the same for both languages when using WPML. However, with the importer, products with the same SKU aren’t imported. To resolve this, we can either assign different SKUs or upload the products without a SKU, allowing the system to generate one automatically. Once the products are imported and the WPML settings are applied, WPML will automatically adjust the SKUs to match across languages. Let me know if this makes sense. Thanks! |
December 18, 2024 at 5:37 am #16524100 | |
fadiS-3 |
Hello, yes i imported using the setting you suggested. I see that the arabic products also uploaded but they were not synced and they were assigned english. I made sure that the sku and ID is not imported |
December 18, 2024 at 5:44 am #16524176 | |
Hello there, I ran the import on your site and it works for me, please check this video: hidden link Let me know if this helps. Thanks |
December 18, 2024 at 7:05 am #16524291 | |
fadiS-3 |
wow that works, i did exactly the same. Let me try it out again on my end and get back pls |
December 19, 2024 at 2:07 am #16528250 | |
fadiS-3 |
Hi there, thanks for the hold. I was able to upload all the products onto the website, but i have another issue with the categories not added correctly. Here is the screencast of the issue that im facing: hidden link Here is the product list that i used to upload the products: hidden link |
December 19, 2024 at 2:40 am #16528303 | |
fadiS-3 |
This is a further analysis of the issue: hidden link |
December 19, 2024 at 5:02 am #16528409 | |
Hello there, I just reimported the product with the link you provided and it didn't even complete, but I can see around 70+ categories in English whereas in your site, it's not that much, so I would suggest you to delete all product and categories from the site, then try to import it in short bulk, lets say 50 first and see if the problem exists. If the error doesn't exists there, try with next 100 and so-on. Let me know if this helps. Thanks |
December 20, 2024 at 2:31 am #16532011 | |
fadiS-3 |
ok im checking this out, let me get back to you shortly |
December 20, 2024 at 4:12 am #16532060 | |
fadiS-3 |
Hi so im tried the way you had instructed. In the first set of the products, i imported from row 2 to 99 and theyimported correctly. I then tried importing row 100 to row 200, and in this set the same issue happened where all the products had one cateogry in english. I also double checked that the arabic products in the sheet do not have the english categories. Can you please advise. Is there a way we can connect and figure this out to expedite this? |
The topic ‘[Closed] Need help with uploading products in both english and araboc’ is closed to new replies.
