Last updated by brentG-3 1 year, 10 months ago.
March 29, 2023 at 7:38 pm #13361963
brentG-3
The various blog posts, example here:
Are not keeping their formatting/layout when translated, example here:
I use Beaver Builder/Beaver Themer for these layouts. What steps should I take to remedy this issue? I know it isn't a bug, but I'm having trouble fixing this. Thank you.
March 30, 2023 at 11:02 am #13366523
I always recommend duplicating the page first before translation as it will always copy over all hidden page options to the translated page. Then, translate the page manually or automatically.
You can refer to this section of the documentation https://wpml.org/documentation/translating-your-contents/displaying-untranslated-content-on-pages-in-secondary-languages/#duplicating-content that explains what I'm trying to do here.
Could you please give this a try and see if it works better for you?
April 4, 2023 at 5:02 pm #13402811
brentG-3
Hello Kor,
I have set the posts for translation, but the page layouts are still not formatted. It seems as though the ACF field groups aren't translating? If I give you a login, would you mind taking a look?
April 4, 2023 at 6:35 pm #13403413
Thanks for your reply.
I would need to take a closer look at your site. So I would need to request temporary access (WP-Admin and FTP) preferably to a test site where the problem has been replicated if possible in order to be of better help and check if some configurations might need to be changed
IMPORTANT: Please, note, a backup is required for security reasons, and to avoid any data loss, you can use the https://wordpress.org/plugins/updraftplus/plugin for these backup needs.
Your following answer will be private, which means only you and I have access to it.
✙ I would need your permission to de-activate and re-activate Plugins and the Theme and to change configurations on the site if required. This is also a reason the backup is critical.
April 5, 2023 at 4:49 pm #13412521
I've fixed the issue by selecting the correct option here hidden link . Could you please check now?
