The client is developing a site and wants to set up automatic translation for WooCommerce elements such as orders, refunds, posts, and subscriptions. They also want to ensure that all frontend elements, including multilingual emails, are translated correctly.
We recommended checking our WooCommerce Multilingual & Multicurrency guide for general setup and specifically our guide on how to translate WooCommerce emails for email translations. For subscription products, we provided a guide to ensure correct translation setup: Translating WooCommerce Subscriptions. We clarified that actual subscriptions should not be translated as the client will only have one subscription regardless of the language.
Please note that this solution might be outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If this does not resolve your issue, please open a new support ticket.
Last updated by Carlos Rojas 3 months, 2 weeks ago.
Assisted by: Carlos Rojas.
March 6, 2025 at 10:14 am #16782380
ericH-23
I am developing a site and want to set up automatic translation for WooCommerce elements such as orders, refunds, posts (shop_order_placehold), and subscriptions. I want all frontend elements to be translated, including multilingual emails.
No specific issue or error message mentioned.
Shall I set the "automatic translation" for WooCommerce elements like orders, refunds, and subscriptions?
How can I ensure that multilingual emails are translated correctly?
March 9, 2025 at 6:55 pm #16793501
Itamar
WPML Supporter since 02/2016
Thank you for contacting WPML support. While you wait for one of my colleagues to take this ticket and work on it, let me provide you with the first debugging steps or see if I can help with the issue quickly.
Please check our WooCommerce Multilingual & Multicurrency guide to see if you can find answers to your questions.
Specifically, for translating WooCommerce emails, please check the following guide.
https://wpml.org/documentation/related-projects/woocommerce-multilingual/how-to-translate-woocommerce-emails/
If you need further help, please share your site's Debug information. You can read about it here.
Itamar.
March 11, 2025 at 7:37 am #16799648
ericH-23
Thanks for the links! I now have a better understanding.
I have a quick question about subscriptions: The subscription products are translated because they are visible to users, but the actual subscriptions are not. Is this setting correct, and will it work without causing any issues?
Thanks, and best regards,
Eric
March 11, 2025 at 10:48 am #16800917
Carlos Rojas
WPML Supporter since 03/2017
Hi Eric,
I'm glad you have a better understanding now.
Here is a guide on how to correctly translate the subscription products: https://wpml.org/documentation/woocommerce-extensions-compatibility/translating-woocommerce-subscriptions-woocommerce-multilingual/ so you can double-check if the configuration on your site is correct.
The actual subscription shouldn't be translated because the client will only have a subscription (regardless of the language) and not one subscription in each language.
Carlos
March 11, 2025 at 10:51 am #16800926
ericH-23
Yes, I know this, here the subscription products are described, but how to proceed with the subscriptions itself, they are managed in the backend and are part of the order, but are not shown to the user. Shall they be set translatable also, or is this not needed?
Thanks, kind regards
Eric
March 11, 2025 at 11:09 am #16801037
Carlos Rojas
Hi Eric,
It is not needed 🙂
March 12, 2025 at 8:09 pm #16809146
ericH-23
Thanks for this info!
March 14, 2025 at 8:06 am #16814919
Carlos Rojas
Please don't hesitate to contact us if you need our help in the future with WPML.
Have an excellent day!
