- | - | 9:00 – 18:00 | 9:00 – 18:00 | 9:00 – 18:00 | 9:00 – 18:00 | 9:00 – 18:00 |
This topic contains 7 replies, has 1 voice.
Last updated by Andreas W. 1 day, 16 hours ago.
February 16, 2025 at 6:02 pm #16711154 | |
yasserS-4 |
February 16, 2025 at 6:05 pm #16711157 | |
yasserS-4 |
After resetting WPML and importing products using WooCommerce Import, all products appear in English only, even those that were originally in Arabic before export. Additionally, translations are not linked to their original content, making manual linking the only available option. Steps taken so far: Products were exported using WooCommerce Export before resetting WPML. All products appear in English only, even those that were originally in Arabic before export. |
February 20, 2025 at 12:36 am #16727085 | |
yasserS-4 |
Why no response what is this bad support |
February 20, 2025 at 8:42 pm #16731317 | |
Andreas W. Supporter Languages: English (English ) Spanish (Español ) German (Deutsch ) Timezone: America/Lima (GMT-05:00) |
Hello, Our apologies for the delay in answering your support request. When creating the export file, did you have "WPML Export & Import" active on the site and which option did you choose to create the exports? Could you maybe send me your exported file to give it a review? Best regards |
February 20, 2025 at 9:59 pm #16731627 | |
yasserS-4 |
Yes, the "WPML Export & Import" plugin was active on the site when creating the export file. We selected the WooCommerce option to create the export. Here is the link to download the exported file: hidden link Please check the file and let us know if there are any issues or adjustments needed. Looking forward to your feedback. |
February 21, 2025 at 3:37 am #16732029 | |
It looks like your export file was not created correctly. WPML and our add-ons need to be active on the site when creating the export. Before exporting you need to go to WPML > Export & Import and set up the export process. It seems like this was not the case, as this export file is missing the columns related to WPML: _wpml_import_translation_group: _wpml_import_language_code: _wpml_import_source_language_code: --- Do you still have a backup from the moment before you reset WPML so that you can create a new export file? If not, you might need to try to adjust the export file manually using the above guide to add the missing columns. |
February 22, 2025 at 12:03 am #16735477 | |
yasserS-4 |
Hello, Thank you for your response and for reviewing the export file. Yes, we do have a backup from before resetting WPML, but it is from six days ago. Since then, we have manually linked most of the products and attributes. However, we are now facing issues such as: Variable products lost their stock status after linking. Continue with the current manual linking process and provide us with solutions to restore missing prices, stock statuses, and attributes. Looking forward to your response. |
February 22, 2025 at 2:26 pm #16736404 | |
It is important to know how the product attributes were created. Custom attributes are created directly on the product, while global attributes are created at Products > Attributes. If you have already manually connected the products, then you can do the following: 1) Edit the original products, save them again, and then let then translate them with the WPML Translation Editor. This will make sure that any custom attributes, that were created directly on the original products, will be available on the translated products. 2) If you are using global attributes, that were created at Product > Attributes, then you need to translate and sync them at WPML > Taxonomy Translation. |
