Last updated by Osama Mersal 1 year, 5 months ago.
Assisted by: Osama Mersal.
August 25, 2023 at 7:51 pm #14293831
victorN-3
Tell us what you are trying to do? Trying to Edit my products i click on filter by category but in category sashimi for example i have 5 products but it shows only 1.
Is there any documentation that you are following? No
Is there a similar example that we can see? not to my knowledge
What is the link to your site? hidden link
August 28, 2023 at 6:53 am #14297431
Osama Mersal
First of all, sorry for the late reply due to a higher workload. On the front end, the mentioned category seems to have 5 products. (Kindly check the attached screenshot)
If you face this issue on the dashboard, please try the following steps:
1- Go to WPML-> Support-> Troubleshooting
2- Run the functions one by one (Kindly check this hidden link)
3- Edit the five products in this category in the default language
4- Make a minor edit and update them
5- Clear the cache and check the issue
❌ Please backup your database before performing the above test ❌
Kindly let me know if the above steps helped you fix the issue.
Osama
September 1, 2023 at 9:16 am #14325377
victorN-3
Hello Osama,
Thank you for your reply and i apologise for the late reply.
Currently the issue is in the backend dashboard but the front end is ok.
Sadly your suggested solution did not result in a solution.
Any other things you can think of?
Cheers,
Vic
September 1, 2023 at 1:03 pm #14326681
victorN-3
Hello Osama,
I have been analysing the problem further and found the following:
If I make a new product and assign it to sashimi category it does not appear in the category when filtering in dashboard but I can see it in all products list.
When copying a current product (does not matter what category) and change it to sashimi category then in appears. you can see it in staging10.sushishore.be. I can provide access when if you ask for it.
Cheers,
Vic
September 2, 2023 at 9:49 am #14329889
Osama Mersal
Hi Vic,
Thanks for your update. I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP)
Your next answer will be private, which means only you and I can access it.
Osama
September 3, 2023 at 7:31 am #14331079
Osama Mersal
Hi Vic,
Thanks for the access details. I tried to reproduce the issue by creating and translating a new product.
After that, I filtered the products in the dashboard using the category, which worked correctly. Kindly check this video. (hidden link)
Please let me know the steps to reproduce the issue.
Osama
September 3, 2023 at 12:15 pm #14331777
victorN-3
Salamat Osama,
Your starting point is from English language, but if you start from the Dutch language then you will see the issue. So ake a product in dutch translate it and then go to woocommerce multilingual products and filter sashimi. Even without creating a new product just search sashimi and you will get all the products (you will see that the products that you cannot see in filter are all originating in the dutch language).
September 3, 2023 at 1:06 pm #14331899
Osama Mersal
Thanks for your update. I've consulted our 2nd tier support regarding this issue and will update you as soon as I get their reply.
Osama
September 5, 2023 at 7:29 am #14340365
Osama Mersal
Thanks for your patience. Our 2nd tier support team has found a workaround for the issue. Please check the following steps:
1- Edit wp-content\plugins\woocommerce-multilingual\inc\template-classes\class-wcml-products-ui.php
2- Go to line 454
3- Replace
if ( $category ) {
	$sql          .= ' AND tx.term_taxonomy_id = %d ';
	$prepare_arg[] = $category;
With
if ( $category ) {
	if (empty($slang)) {
		$cat_translations = apply_filters( 'wpml_get_element_translations', [], apply_filters( 'wpml_element_trid', false, $category, 'tax_product_cat'), 'tax_product_cat');
		$cat_ids = wpml_prepare_in(array_column($cat_translations, 'element_id'), '%s');
		$sql          .= ' AND tx.term_taxonomy_id IN (' . $cat_ids . ') ';
	} else {
I've applied the above steps on the staging site. Please check it and let me know if it works correctly. (hidden link)
Osama
September 6, 2023 at 12:19 pm #14352207
victorN-3
Hey Osama,
thanks for the solution in worked, my remaining question is will this be implemented an update? I am afraid that after an update this code will disappear.
What is your take on that?
Cheers,
Vic
September 6, 2023 at 12:21 pm #14352217
Osama Mersal
Hi Vic,
It's great to hear that the issue is fixed. I'm not sure if this fix will be added to the next release, but our Dev team is aware of the issue, and they will fix it in a future release.
September 6, 2023 at 3:41 pm #14353899
victorN-3
Thanks Osama
