Last updated by Carlos Rojas 1 year, 7 months ago.
Assisted by: Carlos Rojas.
May 10, 2023 at 6:16 am #13618441
bobbyv-3
CartPops cart works slow when wpml is active
May 10, 2023 at 7:17 am #13618715
Bruno Kos
Before we try this in sandbox, can you tell me if you tried asking their support?
Because I can see that this plug-in is not in fact officially compatible with us: https://wpml.org/plugin/?wpv_view_count=120064&wpv-plugin-functionality=0&wpv_post_search=CartPops&wpv-wpcf-recommendation-flag=&wpv_filter_submit=Search, which means that their developers have not applied for our https://wpml.org/documentation/support/go-global-program/ program, which you can definitely suggest them.
The thing is also that I can see on hidden link that they offer "WPML support and translation ready" so given that they are doing this on their own outside our compatibility team, they should also be able to debug this.
In case they are stuck, please suggest they join our https://wpml.org/documentation/support/go-global-program/ so we could work on this together and implement permanent solution for this error.
Bruno Kos
May 10, 2023 at 7:17 am #13618717
bobbyv-3
Hi, i found out there is a conflict with permalink manager. As soon as i enable wpml and permalink manager together, add cart is not functioning right. When i disable one, its working fine again.
It is this plugin https://wordpress.org/plugins/permalink-manager-for-woocommerce
Can you check if you can make this run together pls?
These are the settings of permalink manager hidden link
May 10, 2023 at 9:35 am #13620223
Carlos Rojas
The client opened a chat about this issue and we will continue from there.
This ticket is being closed to avoid duplicates.
