You are trying to display selected English translated posts in other translated languages using Advanced Custom Fields, but face issues where the database query reverts to the current page language. Additionally, using the 'use translation if available or fallback to default language' option disrupts pagination.
We recommend implementing a custom solution where you switch the language on-the-fly to the desired one, query the intended posts, and then switch back to the current language for the rest of the process. This approach is not supported out of the box by WPML, as it is designed to display content based on the "current language" only. You can use WPML's filters and action hooks for proper multilingual support in your theme or plugin. For more details, visit the following resources:
If you require further custom work, consider contacting WPML Contractors at WPML Contractors.
Please note that this solution might be outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If this does not resolve your issue, please open a new support ticket at WPML Support Forum.
Last updated by Waqas Bin Hasan 1 month, 2 weeks ago.
Assisted by: Waqas Bin Hasan.
February 21, 2025 at 1:56 pm #16733908
scottJ-4
I am trying to display selected English translated posts in other translated languages. We can use Advanced Custom Fields to flag an English post that needs to be displayed in other languages, but the database query always seems to fall back to the current page language. We can't use 'use translation if available or fallback to default language' and filter out the posts that are set to display in all languages as this breaks the pagination.
The database query always falls back to the current page language, and using the 'use translation if available or fallback to default language' option breaks pagination.
How can I display selected English translated posts in other languages without breaking pagination?
February 24, 2025 at 7:55 am #16739216
Waqas Bin Hasan
WPML Supporter since 05/2014
As per my understanding, you want to include other translated posts in currently queried post (or translation of the queried post) in the display, which is not possible out of the box and isn't a WPML problem, because WPML is designed to translate the content into other languages and display the content based on the "current language".
You'll need a custom solution which is out of scope of this forum.
As a general idea, you need to switch the language on-the-fly to the desired one, query the intended post(s), grab the results, include in the display and switch back to the current language for rest of the process to continue with the standard flow.
WPML offers filters and action hooks that can be used in your WordPress theme or plugin to provide correct multilingual support. Browse following resources for more information:
- https://wpml.org/documentation/support/wpml-coding-api/
- https://wpml.org/documentation/support/wpml-coding-api/wpml-hooks-reference/
- https://wpml.org/documentation/support/wpml-coding-api/shortcodes/
- https://wpml.org/faq/how-to-get-current-language-with-wpml/
If you need additional custom work, we recommend you contact WPML Contractors at https://wpml.org/contractors/.
Regards.
