You have enabled media translation settings on your site, but you are experiencing issues with images not appearing when using the Advanced Translation Editor. You want to edit the metadata of images so that it appears differently in different languages.
If you're experiencing this issue, we recommend translating your media meta information, such as caption and alt texts, using the Advanced Translation Editor. To display different images on your translated pages, you should use the media translation addon. For detailed guidance, please refer to our documentation on Media Translation.
Please note that this solution might be irrelevant if it's outdated or not applicable to your case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket at WPML support forum.
Last updated by Kor 1 month ago.
February 9, 2025 at 5:10 pm #16684437
yaroslavL-2
I have enabled media translation settings on my site hidden link, but I'm experiencing issues with images not appearing when using the Advanced Translation Editor. I want to edit the metadata of images so that it appears differently in different languages.
Images are not appearing when using the Advanced Translation Editor despite enabling media translation settings.
How can I edit the metadata of images for it to appear differently in different languages?
February 10, 2025 at 7:12 am #16685127
Thanks for contacting us.
You can only translate your media meta information using the Advanced Translation Editor such as caption and alt texts.
If you wish to display another image on your translated pages, you'll have to use the media translation addon as explained here. https://wpml.org/documentation/getting-started-guide/media-translation/
I hope this clears it up.
