Home›Support›English Support›[Resolved] Home english is OK but all other languages not good. Same for other english page
Problem: The client was trying to fix the layout of translated pages to match the English layouts and was unsure if the issue would persist when adding new pages. They also needed assistance with the Spanish page layout.
Solution: We assisted the client by correcting options that were not being saved on the translated page. We asked the client to check if the issue was resolved. For the Spanish page, we provided a specific solution by sharing a video tutorial (https://screenpal.com/watch/cZVfIgVHpzi) that demonstrated the steps we took to fix the layout.
If this solution doesn't look relevant or if you encounter further issues, please don't hesitate to open a new support ticket by visiting our support forum.
Thanks for contacting WPML support. I can see the issue here hidden link .
Also, I noticed that your “WP Memory Limit” PHP limit is below the required 128MB or recommended 256MB as described at: https://wpml.org/home/minimum-requirements/ . Could you please contact your hosting provider and ask them to increase this PHP value for yousc and also, ask them to update the MySQL version to 5.6+?
I realized that I need to edit all the French text and look first. I tested and it seems I cant create french pages and then update english and spanish. I can only edit the english and then it updates french and spanish.
I will erase the english and spanish and build up the french as primary.
I may need your help again to fix the layouts on the other pages.
Sorry for the inconvenience. This is much more work than i thought. I was hoping I could work in either and then translate the text and look to other but I now understand the system.
This will take me a few days so will let you know once i am done.
Hi, the same thing happened and i cant seem to fix. Also I noticed that some of the spanish is not generating the page properly and not translating. could you help please? I have to present soon and cant figure out how to get all pages properly translated into the english and spanish.
French is the good pages. I need to make sure the french is translated into english and french.
Ok I think I got all pages look fixed. Could you just check if all is OK please.
Main thing is the menu accross the 3 languages and trying to make the top menu EN FR SP goto respected page when you click on one.... eg if on CONTACT it will goto contact FR, or contact SP. not just home page.
