The client is experiencing issues with translating the call content of the product aggregation page using WPML. The main content and pictures disappear after attempting to translate the page from English to Chinese.
1. Ensure that the WP memory limit is sufficient. It is recommended to increase the WP memory limit to at least 256MB by adding the following line to the wp-config.php file:
/* Memory Limit */<br />define('WP_MEMORY_LIMIT', '256M');
2. Update all WPML plugins to the latest version, which as of the last update is v4.8.4. This can be done from Plugins -> Add new -> Commercial tab.
3. Update any outdated plugins and themes to avoid conflicts that could affect the translation process. This can be done via the link provided in the WP admin panel.
4. For translating taxonomy terms automatically, follow the guide available at https://wpml.org/faq/how-to-translate-all-taxonomy-terms-at-once/. This includes adding the taxonomy to the content and setting it to translate automatically.
If these steps do not resolve the issue or if the solution seems outdated or irrelevant to your specific case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If further assistance is needed, please open a new support ticket at WPML support forum.
Last updated by Carlos Rojas 6 months ago.
Assisted by: Carlos Rojas.
October 30, 2025 at 4:32 am #17531085
ehaitech-marketing-consultant-
I am trying to translate the call content of the product aggregation page using WPML. The specific page I am working on is hidden link. I need help with the site hidden link.
I am experiencing issues with translating the call content of the product aggregation page.
How can I translate the call content of the product aggregation page using WPML?
October 30, 2025 at 3:57 pm #17533492
Carlos Rojas
WPML Supporter since 03/2017
Thank you for contacting us
1.- Could you describe what you mean by 'the call content of the product'? Can you share a screenshot where this content can be seen?
2.- Please increase the WP memory Limit. Minimum requirements are 128Mb: https://wpml.org/home/minimum-requirements/
You can add this to wp-config.php to increase WP memory:`
/* Memory Limit */
You can double-check the WordPress memory limit in WPML -> Support
3.- Last but not least, update the WPML plugins in Plugins -> Add new -> Commercial tab. The latest WPML version is v4.8.4
Carlos
October 31, 2025 at 1:02 am #17534634
Yes, I have backed up. I can give you the login to the website. The translation location cannot be found
October 31, 2025 at 10:17 am #17535412
Carlos Rojas
Please answer the first point in my previous message so I can understand what you mean by 'the call content of the product'
November 2, 2025 at 3:37 am #17537796
For example, en page:hidden link
After translation to cn:hidden link
problems:the main content and the pictures were disappear. Our team want to translate the whole page successfully from English to Chinese
November 3, 2025 at 9:49 am #17540076
Carlos Rojas
Thank you very much for your message, this time I was able to understand and reproduce the issue.
Please share the access credentials to the site in your next message, which I have set private. This way, I will be able to check the configuration and try to isolate the cause of the issue.
November 4, 2025 at 10:58 am #17544939
Carlos Rojas
Thank you for sharing the credentials requested.
Please update the outdated plugins and themes that appear in this link: hidden link
The outdated functionalities can cause conflict in the code.
November 4, 2025 at 11:03 am #17544952
Carlos Rojas
Once the plugins and themes are up-to-date, edit the category we are using as a reference (hidden link) -> Save the category -> Translate it and double-check if the issue has disappeared.
November 5, 2025 at 9:36 am #17549019
We completed it as required, but the text content of the product page still cannot be translated.
November 5, 2025 at 10:49 am #17549326
Carlos Rojas
Please add the translated texts to the category in chinese: hidden link
November 6, 2025 at 3:20 am #17551978
Is there a way to be automatically translated and recognized by wpml? We have more than 40 pages, and each page has many blocks to add translation
November 6, 2025 at 10:14 am #17552984
Carlos Rojas
Yes, to automatically translate this taxonomy, you need to add it to the content and translate that content automatically. In this FAQ you can read the guide on how to do it: https://wpml.org/faq/how-to-translate-all-taxonomy-terms-at-once/
November 7, 2025 at 1:29 am #17555829
Can you help us adjust the operation directly? My colleague tried this method but it still didn't work. Because of the time difference, our team needs to wait for a long time every time. You can directly translate it to us after it is successfully translated. Our website is backed up
November 7, 2025 at 9:27 am #17556434
Carlos Rojas
Did your colleague try with already translated taxonomies or with untranslated ones?
November 9, 2025 at 3:29 am #17559758
Sorry, I don’t understand what you said.
The first method is successful, but it must be entered manually, which is time-consuming. The second method failed, we tried it with no effect
Here is the second method:
Our team wanted to find a way to automate the translation of category pages.
