The client is experiencing an issue where Hebrew text is not displaying correctly after importing products into WooCommerce; instead of Hebrew characters, question marks (?????) appear.
1. Temporarily deactivate WPML and its add-on plugins to check if the issue persists. This helps determine if the problem is related to WPML or the import process itself.
2. If the issue still occurs with WPML deactivated, it might be a database encoding issue. We recommend checking your database settings to ensure it supports Hebrew characters. You can find guidance on this at https://wpml.org/faq/texts-showing-as/.
3. Verify if the issue is specific to Hebrew or affects other languages as well. This can help isolate the problem.
4. Ensure that the import plugin used is compatible with WPML. The issue might be related to the encoding process within the plugin. A similar issue has been reported here: https://wordpress.org/support/topic/product-csv-importer-not-working-when-the-csv-file-contains-chinese-characters/.
If these steps do not resolve the issue, or if the solution seems outdated or irrelevant to your specific case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket at WPML support forum for further assistance.
No supporters are available to work today on this forum. Feel free to create tickets and we will handle it as soon as we are online. Thank you for your understanding.
This ticket is now closed. If you're a WPML client and need related help, please open a new support ticket.
