Last updated by Long Nguyen 1 year, 8 months ago.
Assisted by: Long Nguyen.
July 24, 2023 at 3:35 pm #14091007 | |
shalomg |
Issue What We Did What This Means: Testing Steps We Took |
July 25, 2023 at 4:58 am #14093005 | |
Long Nguyen WPML Supporter since 02/2022
Languages: English (English ) Timezone: Asia/Ho_Chi_Minh (GMT+07:00) |
Hi there, Thank you for contacting WPML support, I'd be happy to help you with this issue. When enabling the plugin WooCommerce Multilingual (WCML), the product data section of the translation product is locked to prevent manually changing the data in the second language. The data will be synced automatically by WCML. The plugin "Autoship Cloud powered by QPilot" is not available in our list of compatible plugins, which you can check here https://wpml.org/plugin/ Look forward to your reply. |
July 25, 2023 at 1:57 pm #14097097 | |
shalomg |
Hi Long! Thanks for the prompts answer. I had the feeling that the translations are blocked for writing but I was surprised that they are also blocked for reading. I passed over the links to the Qpilot devs to see if they can do something with their API calls to adapt to the WPML logic. Thanks! |
July 26, 2023 at 1:13 am #14099123 | |
Hi, Let me know if you have any questions. Thanks. |
