use ATE to translate a post that contains Kadence Blocks "Testimonial" block
Please go to WPML->Settings->Custom XML Configuration (tab at the top) and add the following
<wpml-config> <gutenberg-blocks> <gutenberg-block type="kadence/testimonial" translate="1"> <key name="title"></key> <key name="content"></key> <key name="name"></key> <key name="occupation"></key> </gutenberg-block> </gutenberg-blocks> </wpml-config>
Then edit the default language page with the blocks -> make small change and update -> access the translation again
Last updated by Lukas Cech 1 year, 10 months ago.
Assisted by: Bobby.
March 15, 2023 at 4:18 pm #13253625 | |
Lukas Cech |
I am trying to: use ATE to translate a post that contains Kadence Blocks "Testimonial" block Link to a page where the issue can be seen: hidden link I expected to see: ATE showing the texts in "testimonials" block for translation Instead, I got: nothing, texts from "testimonials" block are ignored by WPML |
March 15, 2023 at 8:52 pm #13255139 | |
Bobby Supporter
Languages: English (English ) Timezone: America/Los_Angeles (GMT-08:00) |
Hi there, This may be a compatibility issue with the *Kadence Testimonials* Block. I created a sandbox for us to test this with a minimal environment 1) Click this URL to visit the Sandbox site backend - hidden link Let me know your results, please. |
March 16, 2023 at 8:56 am #13257379 | |
Lukas Cech |
Hi Bobby, all set up and not translating, same as my site. Didn't even have to install Kadence Theme (it's not linked to Kadence Blocks, they are two stand alone products). |
March 17, 2023 at 6:58 am #13266523 | |
Bobby Supporter
Thank you for updating me! I have escalated this to our compatibility team and will update you once there is news. In the meantime you can add translation manually by doing the following: 1. View the translated post in the front end hidden link |
April 26, 2023 at 9:34 pm #13545075 | |
Bobby Supporter
Hello, Please go to WPML->Settings->Custom XML Configuration (tab at the top) and add the following <wpml-config> Then edit the default language page with the blocks -> make small change and update -> access the translation again, does it show OK now? |
April 29, 2023 at 11:28 am #13561029 | |
Lukas Cech |
Hi Bobby, this works, now I can translate the teestimonials, thanks. One small issue though - every sentence of a single testimonial is separated and needs to be translated on it's own in ATE, which doesn't make sense. They should be considered as one piece of text (the entire testimonial = one ATE translation box). |
April 29, 2023 at 11:43 am #13561069 | |
Lukas Cech |
and the option to join them manually is unnecessary work + doesn't always work (i.e. in some cases, I don't get the option (chain icon) to click to join them, even if the two sentences are part of a single testimonial. |
May 1, 2023 at 9:03 pm #13566333 | |
Bobby Supporter
Glad to hear it's working now! Thank you for the feedback, this is expected behavior, the sense of joining segments is to make automatic translation work better in case a sentence has too many segments and the automatic translation does not work as expected in terms of grammar or sense. |
May 2, 2023 at 1:45 pm #13571261 | |
Lukas Cech |
Ok, in that case, all is good now. Thanks! |
