The client was experiencing issues with pages appearing translated in the Advanced Translation Editor (ATE) but remaining 'in progress' without completing the translation. Additionally, updates in String Translation for 'elementor-17976' failed, showing 'Translation update failed.'
We recommended the following steps:
1. Create a full backup of the site.
2. Delete the translated page and remove it from the trash.
3. Apply the workaround described on the errata page: https://wpml.org/errata/line-breaks-are-ignored-when-using-the-advanced-translation-edior/
4. Check and apply another workaround for the WPML plugin from: https://wpml.org/errata/wordpress-6-7-mo-files-not-loaded-and-leading-to-missing-translations-on-front-end/
After these steps, if the issue persists, our 2nd tier specialists found an error in Elementor Pro and applied a workaround described here: https://wpml.org/errata/elementor-php-fatal-error-call-to-a-member-function-get_main_id-on-null/
If this solution does not resolve your issue, or if it seems outdated or irrelevant to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If needed, please open a new support ticket at WPML support forum.
Last updated by Carlos Rojas 1 month ago.
Assisted by: Carlos Rojas.
December 6, 2024 at 6:50 pm #16487332
Stéphane
I hope it will !
Thanks for your help Carlos.
Hasta la proxima ! 😉
December 9, 2024 at 11:29 am #16492419
Carlos Rojas
Have an excellent day! 🙂
