The client wants to implement a product schema but couldn't find a certified plugin in the recommended plugins section of WPML. They need a plugin that is compatible with WooCommerce and can work with WPML for a multilingual site.
We recommend using the Yoast or Rank Math SEO plugins to implement and translate product schema, as both are compatible with WPML. For guidance on using these plugins with WPML, you can refer to the following documentation:
If this solution does not apply to your case, or if it seems outdated, we highly recommend checking related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If further assistance is needed, please open a new support ticket.
This topic contains 41 replies, has 1 voice.
Last updated by Shekhar Bhandari 1 week, 5 days ago.
March 6, 2026 at 12:39 pm #17877825
alexZ-17
I want to implement a product schema.
I couldn’t find a certified plugin for schemas in Recommended Plugins for a Reliable Multilingual Site – WPML: https://wpml.org/plugin/
- I don’t know which category to browse, pls advise.
In question is a plugin for product schema.
FYI: I would need also the compatibility with WooCommerce.
I have checked
Rank Math: hidden link
and
Schema & Structured Data: hidden link
with extensions:
WooCommerce Compatibility for Schema: hidden link
WPML Schema Compatibility: hidden link
Background information:
1 Meanwhile I have implemented the e-shop with WooCommerce - in Eglisch only, no WPML translation.
2.1 WooCommerce was implemented only for purchase – the primary source remained the original page (product pages are must in WooCommerce), e.g.
versus
2.2 I use WPML but not for e-shop, that means that a button “Add to cart” is available on pages in other languages (translated), e.g. German - “In den Warenkorb”
but clicking on it results in English WooCommerce page.
3.3 Pages under product subdirectory are not indexed.
March 6, 2026 at 12:43 pm #17877861
alexZ-17
pls reply through support
thx
March 7, 2026 at 10:56 am #17879216
alexZ-17
I do not have a button 'Switch to Human Support'
March 10, 2026 at 4:17 am #17883891
Shekhar Bhandari
WPML Supporter since 03/2015
Thank you for contacting WPML Support. I’d be happy to assist you with this issue.
You can use the Yoast or Rank Math SEO plugins to implement product schema and translate it, as both plugins are compatible with WPML.
The following documentation may help guide you through the process:
https://wpml.org/documentation/plugins-compatibility/using-wordpress-seo-with-wpml/#translate-schema-markup
Please let me know if this helps or if you need any further assistance.
March 10, 2026 at 3:04 pm #17886029
alexZ-17
thank you.
The both docs are for yoast.
Is there anything about Rank Math?
regards
March 11, 2026 at 4:31 am #17887358
Shekhar Bhandari
Hello there,
Please follow the below documentation for rankmath:
https://wpml.org/plugin/rank-math-seo/
https://wpml.org/documentation/plugins-compatibility/optimize-multilingual-websites-using-rank-math-and-wpml/
https://wpml.org/errata/rankmath-rank-math-schema-values-are-not-translated/
Let me know if this helps.
March 14, 2026 at 10:13 am #17897247
alexZ-17
yes it helps.
In https://wpml.org/plugin/rank-math-seo/
it is stated:
"If you run an online store, use the WooCommerce module to add metadata and display search results in a product schema."
Which WooCommerce module is meant - in WPML or in RankMath?
Could you elaborate this issue?
FYI: At the moment I do not translate the WooCommerce - it is only in English
regards
March 16, 2026 at 4:25 am #17898694
Shekhar Bhandari
Yes, this refers to the WooCommerce Multilingual plugin from WPML, which is required for WPML to work properly with WooCommerce.
I look forward to your reply.
March 22, 2026 at 10:49 am #17916519
alexZ-17
I do not understand what for WPML SEO plugin for Rank Math is needed?
I have not installed it yet, but after translating an English page in e.g. German the meta data are correct in Rank Math, cf. attachments
Regards
March 23, 2026 at 3:18 am #17916997
Shekhar Bhandari
This plugin is required for Rank Math to function correctly with WPML, as outlined here: https://wpml.org/documentation/plugins-compatibility/optimize-multilingual-websites-using-rank-math-and-wpml/
While some features may appear to work without it, we won’t be able to provide support if any issues arise unless this required plugin is installed. Our testing has been conducted with this plugin in place, so we cannot guarantee compatibility without it.
Please let me know if this clarifies things.
March 26, 2026 at 2:37 pm #17929603
alexZ-17
Hello when I search in Plugins from WordPress for "WPML SEO" as is suggested in
https://wpml.org/compatibility/2021/04/wpml-seo-plugin-better-integration-with-seo-plugins/
nothing is found.
Why?
FYI: I can download wp-seo-multilingual.2.2.5.zip
regards
March 27, 2026 at 8:19 am #17931040
Shekhar Bhandari
Hello there,
You can download the WPML Seo plugins from here: https://wpml.org/account/downloads/
March 28, 2026 at 7:00 pm #17934207
alexZ-17
This I have already done. The WPML Seo is activated.
New problems.
1 The page is: hidden link.
In this page a schema generated by default (article) was changed to product and the page needs translation.
If I automatically translate this page, ATE translates the names of meta fields, i.e. "@type" - for e.g. EN->GE: template -> Vorlage; Product -> Produkt (schema product); Offer -> Angebot, etc., cf. ATE.EN-DE.mucke-melder-cantilever-armchair-fn21-famos-d-variant-no1_20260328.jpg
I have not saved yet this translation, for me it looks very strange. What do you mean?
2 The message is permanent in WP dashboard:
Please activate the WPML String Translation plugin to convert Rank Math Setting values in different languages.
It is activated and is up to date. So what?
Regards
March 30, 2026 at 6:01 am #17935103
Shekhar Bhandari
Hello there,
To debug this issue further, I would need to check your site settings once, for this I would need temporary access (wp-admin and ftp) to your site.
Note:
Backup your sites before providing the credentials or if possible provide credentials for the test site.
Look forward to your reply.
March 30, 2026 at 9:33 am #17935879
alexZ-17
OK, I will replicate in DEV and provide you with credentials.
It will take some time, I will let you know.
Re 2. : could you please comment
regards
