Slow page speed due to WPML and Woocommerce
We just released a new stable version - WPML 4.6.9 - which should help resolve these performance issues.
If this solution doesn't look relevant, please open a new support ticket here:
https://wpml.org/forums/forum/english-support/
0% of people find this useful.
This topic contains 30 replies, has 3 voices.
Last updated by George Botsev 1 year, 6 months ago.
Assisted by: Itamar.
October 28, 2023 at 9:45 pm #14684701
viktorB-17
Hello Team WPML,
I have been trying to get my website to work for months now.
I have hired multiple people to speed up my website and non of them could figure out why its not possible to speed it up.
I have switched 3 Hosting provider - now I am on Siteground.
I always got told the problem is because of my products have variations so they are probably heavy and load so slow.
Only today we have finally tested if the performance is due to WPML:
1)I have moved all products to trash (except for default language)
2)And then i have deactivated all WPML plugins
3)cleared and loaded cache
= Website has 99 score and loads super fast without WPML
then tried it again
activated WPML & restored products from trash its again super slow - not only products but every page loads slow especially products.
Please help me out! Its been a few frustrating months and I feel like we can solve this soon.
I would really love to keep using WPML as its just what I need to have multiple language stores.
But in this state it slows down my website soooo much its not usable.
I hope you have experience with this and could help me out - that would make my day, week moth and year!
you can check any store front any especially paper cup products are very slow
Best Viktor
October 30, 2023 at 4:10 pm #14693581
Itamar
WPML Supporter since 02/2016
Hi, Viktor.
Here a few suggestions. Please try them.
1. Update WPML to its latest version - 4.6.7. You have version 4.6.6.
2. Deactivate our following add-ons.
- Advanced Custom Fields Multilingual - it doesn't look like you are using the ACF plugin, so there is no point in using our glue plugin.
- WPML CMS Nav - it is most likely you are not using this add-on. If this is correct, please deactivate it.
- WPML Sticky Links - same as the above.
- WPML Media - if you are not using different images per language, you can also deactivate this add-on.
Also, please take a look at our guide on how to Prevent performance issues with WPML.
https://wpml.org/faq/prevent-performance-issues-with-wpml/
By the way, I checked your site, and it loads pretty fast for me. For example, I switched to French for the Paper Cup product, which loaded in under 3 seconds. Please see the attached screenshot.
Itamar.
October 30, 2023 at 7:27 pm #14694761
viktorB-17
Hello Itmar,
Thank you for getting back to me.
1)I have no option to up update to 4.6.7 - there is no update avavilable for me
2) deactivated all plugins you told me to
3) I have read the guide and also follow all of those best practices - website is stil lvery slow.
everything updated
got fast hosting
PHP 7 +
and WPRocket optimized
(as I have meantioned before when i turned all languages off and WPML plugins too - the website turns out to be super fast 99 score 0.1 s loading time - but now its just very slow.
3s to laod a category page is not fast (plus try to click on the left product next to the lids)
any thing else I could do to fix this?
Please help.
Best,
Viktor
October 31, 2023 at 11:18 am #14699019
Itamar
You should be able to see that 4.6.7 is available by following our guide here. (see the section "How can I check for updates?")
https://wpml.org/faq/install-wpml/#checking-for-updates
If the problem persists after updating WPML to 4.6.7, please share with us WordPress's debug log (not WPML debug information). Please check this page for instructions.
To enable it, open your wp-config.php file and look for
define('WP_DEBUG', false);
Change it to:
define('WP_DEBUG', true);
define('WP_DEBUG_LOG', true);
define('WP_DEBUG_DISPLAY', false);
@ini_set('display_errors', 0);
After this, repeat the action that causes the problem on your site (load a slow-loading page). In this case, the errors will be saved to a debug.log log file inside the /wp-content/ directory. Then please share the errors with us.
Itamar.
October 31, 2023 at 12:18 pm #14699493
viktorB-17
Hello Itmar,
I have updated the plugin followed the steps but then my products disappeared - so I have reinstalled my backup and then I did it again - and now it works and shows products - but is still slow - i have no chance to attach the debug log files here so i will copy paste it into the chat-hope this will help you to fix my speed issues:
Error log was moved here: hidden link
November 1, 2023 at 7:24 am #14705391
viktorB-17
I was reading through all the Support Forum Topics - but could not find any solutions to this.
I noticed that a WPML Support person asked once for the plugin query monitor to be installed.
So I did that too now and I am sending you a screenshot attached - for the product page it has 13s loading and 1300+ Queries.
If it helps you and would speed up the process to find a solution - I can provide a admin login to my WP and to my hosting.
Please let me know what what we can do to solve this.
Best,
Viktor
November 1, 2023 at 11:56 am #14707039
Itamar
Hi, Viktor.
Thanks for the error log. From the screenshot, it is hard to tell if there are queries related to WPML.
Privacy and Security Policy
**IMPORTANT**
November 1, 2023 at 3:16 pm #14708751
Itamar
Thanks a lot, Viktor.
I'm consulting our second-tier supporters regarding this problem. It may be that we will need a copy of your site. If needed, do you allow us to install a migration plugin like Duplicator or All In One Migration and take a copy of your site?
November 1, 2023 at 3:20 pm #14708759
viktorB-17
Yes, you are allowed to do anything and everything with my website to try to fix this problem.
I am really frustrated with it and anything that might solve this is perfectly fine with me.
I can give you access to my Siteground account there they have a staging feature which might be useful to you.
If there is anything I can do let me know I will do it asap.
Best,
Viktor
November 1, 2023 at 3:33 pm #14708855
Itamar
Hi, Viktor.
Thanks for allowing us to take a copy of your site.
We are not allowed to get access to a server's control panel. In any case, there is no need for it.
Let's wait fro our second-tier supporters' reply. I'll keep you updated.
November 1, 2023 at 5:09 pm #14709333
Itamar
Our second-tier supporter asked me to escalate this issue to our second-tier supporters' team. I took a copy of your site with the Duplicator plugin (already removed it) and escalated the issue.
I'll keep you updated here on any news regarding this issue.
Thank you for your patience.
Itamar.
November 5, 2023 at 2:51 pm #14733319
viktorB-17
Dear Itamar,
I know its a weekendday now.
But it has been a few days now.
Would you be able to give me an update or a time fram for how long approx. it will take to get an update?
Were you able to find a solution yet?
Best,
Viktor
November 5, 2023 at 5:39 pm #14733721
Itamar
Hi, Viktor.
Our second-tier supporter did find the cause of the performance issue. He found that with the copy of your site on his local server, there is a big performance improvement when he disables the following functions in the functions.php file of the child theme of your site.
//add_action( 'wp', 'move_upsells_after_related', 1010 );
//add_filter('woocommerce_get_price_html', 'lw_hide_variation_price', 10, 2);
//add_filter( 'woocommerce_ajax_variation_threshold', 'woocommerce_increase_variation_limits', 100, 2 );
Please try it on your site and see if it helps.
Itamar.
November 6, 2023 at 10:51 am #14736705
viktorB-17
Hello Itamar,
I have applied the changes - and i see a minor improvement. in the products load speed.
But its no where close to how the website works without WPML if you only use one language.
This is stil lvery slow and not todays standard.
Unless you have a better slution to this - I think I wont be able to use WPML for this project.
If you are not able to find a solution to this I would kindly request a full refund due to performance issues like you guarantee on your website. as stated in your performacnce guarantee :: https://wpml.org/faq/prevent-performance-issues-with-wpml/
Thank you for your help.
Best Viktor
November 6, 2023 at 2:03 pm #14738631
Itamar
Hi, Viktor.
I have sent your reply to our second-tier supporter. Let's please wait for his reply on this matter.
Itamar.
