The client was experiencing issues with their WPML plugin after switching hosting providers. The plugin was not connecting properly, and they were receiving a cURL error 28. The hosting provider's investigation suggested that the plugin might need to be reconfigured due to the hosting switch.
1. We advised the client to unregister their site from WPML and then register it again.
- Unregister: https://wpml.org/faq/install-wpml/#unregister
- Register: https://wpml.org/faq/install-wpml/#register
2. We instructed the client to check the Installer Log under WPML > Support to ensure the subscription was working correctly.
3. We asked the client to go to Plugins -> Add New -> Commercial and click 'Check for Updates' to see if any messages appeared.
4. We identified that WPML might be blocked by a firewall and recommended contacting the hosting provider to whitelist certain domains:
  • wpml.org
  • cdn.wpml.org
  • api.wpml.org
  • api.toolset.com
  • cloudfront.net
More information: https://wpml.org/faq/wpml-plugin-cannot-connect-to-wpml-org/
5. We performed tests on a staging site and confirmed that the Automatic Translation Editor (ATE) was connected without errors and that WPML registration was possible. We suggested that the server might need to have the IP addresses of our domains manually added to the /etc/hosts file due to DNS resolution issues.
If the solution provided here does not resolve your issue or seems irrelevant due to being outdated or not applicable to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If you still need assistance, please open a new support ticket with us.
This topic contains 23 replies, has 3 voices.
Last updated by Bobby 1 year, 5 months ago.
Assisted by: Bobby.
February 15, 2024 at 7:31 pm #15309253
julienB-61
I asked the provider to check the point 3 and here is their reply:
February 15, 2024 at 10:13 pm #15309630
Bobby
WPML Supporter since 04/2015
Thank you for updating me, please ask them to include the IPs that come from the following domains
wpml.org
cdn.wpml.org
api.wpml.org
api.toolset.com
cloudfront.net
possibly manually added to /etc/hosts file
Based on the wpml: cURL error 28: Operation timed out after 45009 milliseconds with 0 bytes received
There was a temporary slow-down between your server and WPML.org please also share that with them
February 16, 2024 at 8:20 am #15310352
julienB-61
Hello, here is their reply regarding point 3:
and Qmonitor stats are high.
Have you whitelisted the pvoder IP at all?
February 16, 2024 at 8:56 am #15310468
julienB-61
Here is their IP to whitelist: 35.239.178.247
February 16, 2024 at 1:35 pm #15311878
julienB-61
Here si the last update the provider applied and the API connection seems to be resolved.
an issue left is the error message on top of the plugin list.
February 16, 2024 at 6:57 pm #15312932
Bobby
Thank you for sharing the updates with me!
Going to WPML->Troubleshooting->Installer Support and checking the connection it is working OK now.
What they explained in the last screenshot is most likely what is causing this issue and it seems like they fixed it on their side.
I was able to go to Plugins->Add new->Register WPML and then the warnings were removed.
February 16, 2024 at 7:06 pm #15312952
julienB-61
It seems to be working now.
I'm testing a bit more to be sure
February 16, 2024 at 7:56 pm #15313007
julienB-61
I did the config like on the screenshot with new keys on both env. and it seems to be working for now.
Let's see in the coming hours if everything remains the same.
Thank you very much for your support and your colleagues too!!!
The duplicate Cloudflare was the 1st reason for the connection issue and the 2nd was the attached screenshot.
Julien
February 16, 2024 at 10:33 pm #15313253
Bobby
You are welcome, my pleasure.
I will wait for your update, if all is well feel free to mark this as resolved 🙂
February 19, 2024 at 7:18 am #15316042
julienB-61
Thank you
