I get WPML.org cannot connect error on my website and I re-registered the website without success.
- Go to WPML > Support > Troubleshooting (link).
- Click the buttons below:
* Synchronize translators and translation managers with ATE
* Synchronize local job ids with ATE jobs
Relevant Documentation:
https://wpml.org/faq/wpml-plugin-cannot-connect-to-wpml-org/
Last updated by Autopark312 1 year, 8 months ago.
June 16, 2023 at 9:40 pm #13842715
Autopark312
1- Go to your account page (https://wpml.org/account/sites/)
2- Delete the key for the site
3- Go to plugins-> Add new-> Commercial tab
4- Click on "Unregister WPML from this site"
5- Click on "Register WPML"
6- Click on "Get a key for this site" (Kindly check the attached screenshot)
7- Register the site and enter the key
June 19, 2023 at 6:02 am #13846837
Christopher Amirian
It seems that you follow the steps you mentioned and you still have registration issue.
I'd appreciate it if you could give me the URL/User/Pass of your WordPress dashboard after you make sure that you have a backup of your website.
I will try to test with my key and see if it works or it is some sort of communication issue within the site and wpml.org.
June 19, 2023 at 10:48 am #13850453
Autopark312
I have a backup. Where to send login information ?
June 19, 2023 at 12:21 pm #13851495
Christopher Amirian
Ok thanks, please set the next reply as private and you will see the option to give the login info.
June 20, 2023 at 7:45 am #13856463
Christopher Amirian
Thank you for the login information. You did register WPML correctly and there was no need to change anything.
I refreshed the communication from the troubleshooting section WPML support menu and it worked and there is no connection error anymore.
For more information:
