This topic contains 20 replies, has 0 voices.
Last updated by Itamar 6 days ago.
Assisted by: Itamar.
July 3, 2025 at 6:55 pm #17199101
Maximilian Wellner
sure
July 3, 2025 at 8:05 pm #17199192
Itamar
WPML Supporter since 02/2016
We need to replicate this issue on a fresh WordPress installation. Then, if needed, I'll be able to escalate it to our compatibility team. To achieve this, I created a test website with a clean WordPress installation. You can access it through this link:
Could you please install the Advanced Product Fields Addons plugin and see if the issue is replicable on a clean WordPress installation?
I already configured WPML to have German as the default language and English as the second language. Please configure WooCommerce as it is set on your site (just the basic configurations needed to replicate the issue are sufficient).
Please also make sure that you are installing the latest version of the plugin.
Please follow the guide at hidden link. When switching off WPML's Advanced Translation Editor, you must translate the products as described here: https://wpml.org/documentation/translating-your-contents/using-different-translation-editors-for-different-pages/. This means you need to work with the WordPress editor.
When everything is finished and you can replicate the problem, please let us know.
Important! Do not import your site to the test site. We must replicate the problem on a fresh, clean WordPress installation.
Itamar.
July 13, 2025 at 12:36 pm #17231033
Maximilian Wellner
Can you test this too if you are taking a copy of the site? (As mentioned in the other support thread?)
July 13, 2025 at 7:08 pm #17231360
Itamar
The best way would be to replicate this issue on the sandbox site. I can try to help further by testing it on a copy of your site, but it might take longer. As I'm unfamiliar with the Advanced Product Fields for WooCommerce plugin, could you please guide me through the steps to replicate the issue?
Itamar.
July 18, 2025 at 3:28 pm #17251419
Maximilian Wellner
sure I can guide you. Please create a random test product. And on the bottom of the page where the product data is you can find the "custom fields" tab .
There you can add some product options. Then try to translate the product
July 21, 2025 at 5:20 pm #17256987
Itamar
Thanks for your instructions. I tested this issue on a copy of your site on my local server.
By following the manual translation method described in the following link, I was able to translate the fields.
This method requires first duplicating the product into the secondary language and then translating it independently.
However, the fields are not showing on the translated product on the front end.
Does this problem also occur on your site?
Itamar.
July 24, 2025 at 10:29 am #17266923
Maximilian Wellner
"nd then translating it independently." so you duplicated it first, and then how did you do the auto translation exactly?
July 24, 2025 at 8:44 pm #17269243
Itamar
I didn't translate the product automatically. I manually translated it.
The point I was trying to stress is that the fields I created on the test product were showing in German. Please see the attached screenshot german-ok.jpg. But not in English. Please see the attached screenshot en-no-fields.jpg. So I'm asking you if that is what also happens on your site?
Please note that my weekend hours are Friday to Saturday. If you need further assistance, I'll be available to continue checking this issue and helping you next week.
Itamar.
July 30, 2025 at 10:54 am #17281609
Maximilian Wellner
yes I can confirm this happens on my site too
August 1, 2025 at 7:32 am #17287158
Itamar
Thanks for confirming this.
The Advanced Product Fields for WooCommerce by WebToffee is officially compatible with WooCommerce Multilingual & Multicurrency.
https://wpml.org/plugin/advanced-product-fields-for-woocommerce/
However, we might be facing a new compatibility issue that has not yet been reported. We need to replicate this issue on a fresh WordPress installation. Then I'll be able to escalate it to our compatibility team. For this, I created a test website with a clean WordPress install. You can access it through this link:
I've configured WPML to have German as the default language and English as the second language. I've also set up WooCommerce and added some sample products.
Could you please install the Advanced Product Fields for WooCommerce plugin and see if the issue is replicable on a clean WordPress installation?
Itamar.
August 1, 2025 at 11:17 pm #17289617
Maximilian Wellner
Hi Itamar,
I installed the plugin but cant use it as it asks to enter the license key
"Fields — Add custom fields to this group.
Thank you for installing our plugin. Please activate your license first."
Please also note, this is not a plugin by web toffee, but this one https://wpml.org/de/plugin/advanced-product-fields-for-woocommerce/
August 3, 2025 at 8:09 pm #17291335
Itamar
Thanks for installing the plugin on the sandbox site.
I couldn't find a license for this plugin. I've sent a message to our compatibility team asking them if they have a license code for it.
I'll update you once I have their reply.
P.S. I'm sorry, it was my mistake. The plugin is by Wombat. However, it is the plugin I referred to. I just got the author wrong.
Itamar.
August 5, 2025 at 1:20 pm #17296713
Itamar
Unfortunately, we don't have a license for the Advanced Product Fields for WooCommerce plugin. Please get in touch with Studio Wombat, the authors, if this plugin and ask for their cooperation with this issue. They manage the compatibility with WPML. They should be able to help. You can share this thread with them and the access to the sandbox site so they will activate the plugin. Then our compatibility team will be able to continue to check this problem.
Itamar.
August 6, 2025 at 10:49 pm #17300953
Maximilian Wellner
they told me: You can give your license key or you can ask them to contact us to get one. If their sandbox follows the dev URL format, they can use your license and it does not count towards your license activations.
how do we proceed?
August 7, 2025 at 6:18 pm #17303639
Itamar
Thanks for sharing the reply from the authors of the plugin.
I've shared this with our second-tier supporter and compatibility team to understand how we can get forward with investigating this issue. I'll update you here once I have news about this issue.
Itamar.
