This topic contains 11 replies, has 3 voices.
Last updated by stevenH-12 1 year, 10 months ago.
Assisted by: Yvette.
June 17, 2022 at 9:15 am #11483559 | |
stevenH-12 |
Since a week or 2 I have a problem with translated (variable ?) products in woocommerce: every now and then the translated products turn to 'out of stock'. It's not just some variations but the entire variable product that is marked as 'out of stock'. When I check the list of products, these 'out of stock' products do not list as sold out. |
June 17, 2022 at 9:48 am #11483755 | |
Itamar Supporter
Languages: English (English ) Hebrew (עברית ) Timezone: Asia/Jerusalem (GMT+03:00) |
Hi, Please share with us the access to your staging site so we can continue investigating the issue. Also please mention a product that experienced this problem. If you need further help with this, please share the access details to your site with me. Privacy and Security Policy We have strict policies regarding privacy and access to your information. Please see: **IMPORTANT** - - Please make a backup of site files and database before providing us access. --
June 17, 2022 at 2:46 pm #11486161 | |
Yvette Supporter
Languages: English (English ) Spanish (Español ) Timezone: Europe/Paris (GMT+02:00) |
Hello At this moment, when I try to view the product that you provided as an example of the issue, I am getting a 500 internal server error. Do you get this as well? |
June 17, 2022 at 3:36 pm #11486501 | |
stevenH-12 |
Yes, I had the same error. there was something wrong with the htaccess file. It should work now. |
June 20, 2022 at 8:27 am #11496665 | |
Yvette Supporter
I checked the stock status of the product you provided but everything seems to be in order. Have I missed something? You originally asked: 1. if this is a known bug since the major woocommerce update of WPML? 2. And is there a way I can solve this recurring problem? A software bug will occur regularly and is easily reproduced. The error is logical. That is not to say that it is NOT a bug...but we cannot study what cannot be reproduced. I wait for your feedback |
June 20, 2022 at 11:21 am #11498385 | |
stevenH-12 |
I mentioned that the problem is recurring, because it is. At the moment we're experiencing the problem again on the live site, I have now pulled the database from the live site to the staging site, so you can see where the problem is. |
June 20, 2022 at 11:41 am #11498595 | |
Yvette Supporter
You wrote: "As far as I can see (it's a guess) the translated product (Dutch) turns to 'out of stock' when a client makes an order in the original language (French) and the problem only occurs in variable products" Could you reproduce this on the staging site? IF so - that would be fantastic. |
June 20, 2022 at 12:19 pm #11498997 | |
stevenH-12 |
I have now pulled the entire database from live to staging and the products I mentioned at the start of this thread are 'out of stock' in the translated product page (Dutch). There's nothing in the admin that shows me the product is out of stock. On the frontend the product page says 'out of stock', in the list of products it just show 'in stock'. So there is a discrepancy between frontend and backend. I fixed the problem (again) on the live site, by just updating the translation, without making any changes. The product is 'in stock' again on the frontend. But I can't tell when it is going to change again. The fact that the error disappears after updating the translation leaves me to believe there is something wrong within synchronisation of stock between translations, when a product gets ordered in the original language. As I said before: it is the main product that goes out of stock and not just a variation of that product. I tried to trigger the error on the staging site, by ordering avariable product in the original language, but it did not trigger the error, being that the translation goes 'out of stock'. I also tried and disabled all plugin except woocommerce and WPML plugins to see if that changed something with stock, but it didn't. |
June 20, 2022 at 4:50 pm #11501717 | |
Yvette Supporter
Hello I took a Duplicator package of the staging site and installed it on a local server. With this copy, I had to remove the MU plugin for caching. When I did this, the product was not showing the out-of-stock issue curiously. Could you please try removing the MU plugin from the staging site? As you pointed out - the backend data is ok - it's the frontend that is not working. |
June 20, 2022 at 5:28 pm #11502043 | |
stevenH-12 |
I can't fully delete it, but I can disable it and the problem is still the same. |
June 21, 2022 at 7:28 am #11505547 | |
Yvette Supporter
At this point, do you agree that we are looking at a caching issue? I am not sure what the status of the Redis is on your site and if activating it has now resolved "the issue" or not. Can you please clarify? Is this the only caching strategy you have active at the moment? |
June 24, 2022 at 11:51 am #11537577 | |
stevenH-12 |
Yes, this was a caching issue causing translated products to go out of stock when the original product was bought. |
