Sending a lot of jobs for translation from the translation basket fails.
Increase the max execution time, max input vars to 10000 if this helps or the easy option send strings in smaller batches.
Relevant Documentation:
https://bobcares.com/blog/increase-max_execution_time-in-wordpress/
Last updated by mohamed-nawfelO 4 years, 2 months ago.
Assisted by: Itamar.
October 18, 2020 at 10:50 am
mohamed-nawfelO
There are 2679 jobs in the translation basket. And the ending them to translations fails each time.
3:14 PM
Sending your jobs to translation
Batch #1
Rollback jobs...
October 18, 2020 at 1:01 pm
October 18, 2020 at 1:11 pm
October 18, 2020 at 1:11 pm #7251967
Itamar
Hi.
Please see my private reply here above.
Itamar.
October 18, 2020 at 6:42 pm #7253061
mohamed-nawfelO
Hi Itama, I would like to know whether you managed to coy my site so I can retrive my backup.
October 18, 2020 at 7:30 pm #7253173
Itamar
I'm sorry if I was not clear enough but you need to proceed with the migration of your site with the instructions I sent you in the private reply here.
https://wpml.org/forums/topic/a-problem-with-sending-jobs-for-translation/#post-7251965
Please let me know if you need help with this.
Itamar.
October 18, 2020 at 9:52 pm #7253303
mohamed-nawfelO
Got it thanks. I've launched the migration. It did not ask me for database credentials. Is that okay?
--image removed by the supporter--
October 18, 2020 at 10:12 pm #7253329
mohamed-nawfelO
This was quick! The migration is already complete. You may access the staging site here:
FYI I took few notes during our chat. This is what we have tried already:
1. Increase memory limit to 512
2. Deactivating all plugins
3. Using standard theme
4. Activating debug (but no debug.log created when trying to trigger the error)
As a reminder, the website is hosted on a Godaddy Managed Pro+ Hosting plan.
Hope this help. And thank you for taking the time.
October 19, 2020 at 8:58 am #7255909
Itamar
Hi and thanks for migrating your site to our servers.
I was able to access the admin of your site although I have the DB access.
I'll try some more hacks and keep you updated here.
Thank you for your patience.
Itamar.
October 19, 2020 at 9:05 am #7256065
mohamed-nawfelO
Great
October 19, 2020 at 4:12 pm #7259855
Itamar
Hi.
Update
I'm still trying to get access to your site. It seems that there are a lot of security features on the server of your site and they make trouble also on the migrated site on our server. I'll keep you updated here. I will reply tomorrow.
Itamar.
October 19, 2020 at 4:35 pm #7260139
mohamed-nawfelO
That's good to know. Although we are only using Sucuri which comes bundle in the Godaddy offers. So if you only deactive the sucuri plugin then perhaps it will work.
October 20, 2020 at 1:06 pm #7266033
Itamar
Finally, I was able to recreate your site on my local server and enter it. I managed to do that after importing only the wp_ (default WordPress tables) and icl_ (WPML DB tables) database tables to a fresh WordPress installation. And on my local server with this form of a copy of your site, I was able to send all the 2679 jobs from the Translation Basket to the Translation Jobs tab.
I'm currently consulting our second tier supporters on how to help you further with this issue.
Itamar.
October 20, 2020 at 4:02 pm #7268251
mohamed-nawfelO
Thank you Itamar for keeping me updated, I look forward to getting this fixed 🙂
October 20, 2020 at 5:08 pm #7268657
Itamar
Hi.
Our second tier supporter checked this issue on the copy of your site on our server.
He was able to access the site after making the proper change in the wp-config.php file.
Here is what our second-tier supporter reports.
I tried to send the strings, it took almost 10 15 minutes but finally sent.
You can see it in WPML -> Translation Management -> Translation Jobs.
You can access a copy of your site on our server with the same credentials that you gave me.
Our second tier supporter suggests trying the following.
These are the values on your site now.
TimeLimit	300
MaxInputVars	3000
Please refer to the following links to know how to increase the above.
Please let me know if you need help with that.
Itamar.
