Sending a lot of jobs for translation from the translation basket fails.
Increase the max execution time, max input vars to 10000 if this helps or the easy option send strings in smaller batches.
Relevant Documentation:
https://bobcares.com/blog/increase-max_execution_time-in-wordpress/
Last updated by mohamed-nawfelO 4 years, 1 month ago.
Assisted by: Itamar.
October 20, 2020 at 6:29 pm #7269013
mohamed-nawfelO
Hi, I have increased both values to 10000 and it worked! Than you so much for the great support.
I have one last question. Should I keep TimeLimit and MaxInputVars to 10000 now that I am done translating or put the old values back?
October 20, 2020 at 6:57 pm #7269131
mohamed-nawfelO
The translation worked perfectly. Could let me know how to send product categories and product attribute to automatic translation? that's my last question I promise 🙂
October 21, 2020 at 6:56 am #7272083
Itamar
Great, I'm glad that it is solved now!
You asked: "I have one last question. Should I keep TimeLimit and MaxInputVars to 10000 now that I am done translating or put the old values back?"
For MaxInputVars you can keep those values like that.
As for the TimeLimit I think that you can also keep it like that. Although you should be aware of the security risk that it might inflict. Please read about here.
You also asked: "Could let me know how to send product categories and product attribute to automatic translation?"
When you send products for translation that include categories and attributes that need a translation, they will be automatically translated with the products. Currently, there is no option to send categories and attributes separately for automatic translation.
https://wpml.org/documentation/automatic-translation/
Good luck with your web projects 🙂
Itamar.
October 21, 2020 at 10:13 am #7273567
mohamed-nawfelO
My issue is resolved now. Thank you Itamar!
