This topic contains 40 replies, has 3 voices.
Last updated by Bigul 4 years, 1 month ago.
Assisted by: Bigul.
May 26, 2020 at 4:48 am #6215267 | |
francescoL-19 |
Hello, I'm Francesco from Italy. I'm not very expert of WP. My website has 50 plug-ins and the database size is 100MB. wp_icl_strings wp_icl_translate I already pressed all button in the WMPL troubleshooting page, and they helped. In attachment the database info extracted from the Duplicator plugin. Thank you! =) |
May 26, 2020 at 9:01 pm #6223535 | |
francescoL-19 |
Hello.. I need help! |
May 27, 2020 at 8:06 pm #6232749 | |
Bigul Supporter
Languages: English (English ) Timezone: Europe/Vienna (GMT+01:00) |
Hello, Welcome to the WPML support forum. I will do my best to help you to resolve the issue. We have released a new version recently and it has many improvements. So please try the following steps after a full site backup and check is there any difference in the result. 1) Upgrade to the latest version of WPML(4.3.14 series) and WooCommerce Multilingual(4.9.0) - Clear the cache in WPML May you have to visit Plugins>>Add New>>Commerical tab and click on *Check for updates* button to get the upgrade links. This step will help us refresh the installer caches. Now WPML is releasing as a batch in the first few days of the release. So the upgrade notice will be visible only to a few of the customers. The count will increase each day. It will help us handle the situation easily incase of any bugs in the release. -- Bigul |
May 28, 2020 at 12:57 am #6233889 | |
francescoL-19 |
Hello, I don't see yet the new update. I think I need to wait... How can I do it? |
May 28, 2020 at 10:40 am #6238007 | |
Bigul Supporter
Hello, Thank you for the updates. It requires further checking. Because removing the entries directly from the Database tables will make conflicts in the data relationships. Therefore please try the following steps after a full site backup and make sure the issue exists or not. 1) Go to Plugins>>Add New and select *Commerical* tab - Clear the cache in WPML -- Bigul |
May 28, 2020 at 3:31 pm #6241087 | |
francescoL-19 |
HGi, ok, I did id and, and the wp_icl_translate still huge (42 MB)... |
May 28, 2020 at 6:41 pm #6243277 | |
Bigul Supporter
Hello, Thank you for the updates. Please fill the private details fields after a full site backup. I would like to access the admin area of your site for further checking. Please check the following links for more details about our private information sharing policies. hidden link Also please allows me to make a duplicator copy of your site using the Duplicator plugin(https://wordpress.org/plugins/duplicator/) for debugging the issue on my local server. -- Bigul |
June 1, 2020 at 6:04 am #6263013 | |
Bigul Supporter
Hello, Thank you for the details and Duplicator package. I will debug the issue further and get back to you as soon as possible. Please wait. -- Bigul |
June 2, 2020 at 8:14 pm #6277253 | |
Bigul Supporter
Hello, I am still working on this issue. The *wp_icl_translate* and *wp_icl_strings* tables shows same size in my local copy after the initial troubleshooting steps. Therefore I am consulting about this with our second-tier team for the expert opinion. We will get back to you as soon as possible. Please wait. -- Bigul |
June 5, 2020 at 2:03 am #6299725 | |
francescoL-19 |
Hello Bigul, How did you solved the wp_icl_translate problem? |
June 5, 2020 at 2:39 pm #6306555 | |
Bigul Supporter
Hello, We are still troubleshooting the issues. It looks like the *wp_icl_translate* and *wp_icl_strings* tables showing as big because of the following. 1) The size of wp_posts and wp_postmeta tables are 10 and 20 MB. It shows the same after resetting WPML on our local copy. Please check the attached images for more details. 2) There are 15,000+ strings for translation, please visit WPML>>String Translation panel to check it Therefore we would like to know do you have site backup before installing the WPML on your site. -- Bigul |
June 5, 2020 at 2:49 pm #6306651 | |
francescoL-19 |
Hi Bigul, your picture are too small =) . I'm not able to see... |
June 5, 2020 at 3:00 pm #6306763 | |
Bigul Supporter
Hello, Thank you for the updates. The one with WPML will not be much helpful. As of now, it is a kind of expected result. Because the wp_posts and wp_postmeta tables size. Please check the attached images now. Sorry for the small ones. -- Bigul |
June 5, 2020 at 3:03 pm #6306873 | |
francescoL-19 |
So, from what I understood, we cannot do nothing, right? |
June 5, 2020 at 4:07 pm #6307279 | |
Bigul Supporter
Hello, I have shared the details with our team and waiting for the expert opinion. But it will be almost normal. Because *wp_icl_translate* table will be keeping the translations data of wp_posts, wp_postmeta, wp_terms etc.. -- Bigul |
