The client was unable to translate products using Elementor after installing the WPML plugin. Certain text within the Product Template was not appearing in the WPML translation editor.
1. We advised the client to set the Woodmart Layouts to "Translatable" in WPML > Setting > Post Type Translation > Layouts (woodmart_layout) and then proceed to translate them.
2. For the untranslated string in the footer bar, it should be translated using WPML > String Translation. If the string is not visible there, the client should follow the guide to find and register the string for translation: finding strings that don't appear on the string translation page, and ensure the correct source language is set: how to change the source language of strings.
3. We recommended changing the WPML settings from "Translatable - use translation if available or fallback to default language" to "Translatable only show translated items" for both products and templates to ensure proper functionality.
4. We installed an update for the WooCommerce Multilingual addon to address compatibility issues, detailed here: WooCommerce Multilingual 5.5.0.
If this solution does not resolve your issue or seems outdated, we recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If problems persist, please open a new support ticket.
This topic is split from https://wpml.org/forums/topic/the-home-page-has-reverted-from-english-to-its-original-language-2/
Tagged: Documentation request, Exception, Known issue
This topic contains 43 replies, has 0 voices.
Last updated by Andreas W. 10 months, 2 weeks ago.
| Author | Posts |
| May 22, 2025 at 10:40 am #17060956 | |
milijanM |
For some reason I can't translate products the same way I translated individual pages. The problem is that elementor won't start at all when I try to edit the page through elementor! When I start Elementor trying to open the Product Layout then everything works but if I try to open the product through Elementor it doesn't work. I tried deactivating Product Layout but even then it didn't work, I don't know if it's some problem with WPML again or not but I know everything was working as it should be before I installed your plugin! hidden link - I just found out that your String Translation plugin was causing a serious problem and was the cause of me not being able to launch the Product Page using Elementor!!! When I turned it off I started the page normally...I really don't know how I'm going to finish this project with a bug like this |
| May 22, 2025 at 10:48 am #17061013 | |
milijanM |
See for example this problem here, this text I've boxed in red doesn't appear in the Translate editor. Look at picture 1 and 2. The text that is framed in red is in the Product Template and as such it is not possible to translate it through elementor and it does not appear in the Translate editor nor can I find it in any way through WPML! Watch the video. hidden link Product Layout controls the appearance of the first part of the product where the Add to Cart button is, while the second part with tabs and descriptions is fully customizable and can be translated according to current practice using Elementor! |
| May 24, 2025 at 5:36 pm #17068956 | |
Languages: English (English ) German (Deutsch ) Timezone: America/Lima (GMT-05:00) |
Hello, Could you please manually check if the Woodmart Layout Display Conditions are correctly set on the translated layout? Further, it seems the minimum requirements on the server are not met: Could you please increase the WordPress memory limit (WP Memory Limit) to at least 256 MB? WPML requires at least 128 MB. PHP Memory Limit 2G To do this, you need to connect to your website's server and open the wp-config.php file in a text editor. The file is located in the WordPress root directory. Add this code to the wp-config.php file to increase WordPress's memory:
define ('WP_MEMORY_LIMIT', '256M');
Add this just before this comment: // That's all, stop editing! Happy blogging. The current values can be viewed under WPML > Support > WordPress. These settings can be restricted directly by your hosting provider. Therefore, I recommend contacting them and asking them to change them directly if the changes are not applied immediately. Best regards, |
| May 24, 2025 at 9:18 pm #17069159 | |
milijanM |
1. Could you please manually check if the Woodmart Layout Display Conditions are correctly set on the translated layout? ME: And could you explain to me how to do that? 2. Further, it seems the minimum requirements on the server are not met: Could you please increase the WordPress memory limit (WP Memory Limit) to at least 256 MB? WPML requires at least 128 MB. PHP Memory Limit 2G ME: I already did this part when I started communication with Noman, so I don't understand why you still see the incorrect value??? 3. These settings can be restricted directly by your hosting provider. Therefore, I recommend contacting them and asking them to change them directly if the changes are not applied immediately. ME: What does this even have to do with the fact that I can't translate parts of the text that are in the Woodmart Product Layout, I really don't understand this??? That's how Noman initially thought that the problem was in the server settings, so it turned out that the problem is in your plugin! |
| May 24, 2025 at 9:22 pm #17069177 | |
milijanM |
I don't think you've seen it right or we're not looking at the same parameters... |
| May 24, 2025 at 10:00 pm #17069215 | |
Thank you for confirming that your site fulfills the minimum requirements to run WPML. We ask for this adjustment because if the memory usage is higher than the memory limit, changes will not be displayed on the website or appear after a long delay. To revise the layouts display conditions you can go to the Layouts list page and switch the language using the language filter or the admin language switcher in the top admin bar. Now, that you view the translated layouts, use the Woodmart options for the Layout to revise if the display conditions are set properly. --- If you need further assistance, I would like to request temporary access (wp-admin and FTP) to the website to investigate the issue further. You can find the required fields below the comments section when you log in to leave the next reply. The information you provide is private, meaning only you and I can see and access it. IMPORTANT I may need to install a plugin called "All In One WP Migration" to create a copy of the website so I can investigate the issue further. However, I would also be very grateful if you could provide a staging site or a copy of the website from your server for this purpose. If you have any questions about creating such a staging site, you can consult your hosting provider. Please note that WPML must also be registered on this staging site at https://wpml.org/account/websites/. If you are unable to provide such a copy of the website for testing, please let me know on this ticket. The private reply form looks like this: Click "I still need assistance" the next time you reply. Video: Please note that we are required to request this information individually on each ticket. We are not permitted to access any credentials that were not specifically submitted on this ticket using the private response form. |
| May 27, 2025 at 8:49 am #17076509 | |
milijanM |
When can I expect someone to reply to my last message? |
| May 27, 2025 at 10:28 am #17077191 | |
You have not yet translated the Woodmart Layouts. I have set them now to "Translatable" at WPML > Setting > Post Type Translation > Layouts (woodmart_layout). Please go to "Layouts" and translate them. |
| May 29, 2025 at 8:53 am #17087073 | |
milijanM |
Should I turn off the String Translation plugin before translating the Layout or not? Norman told me I should turn it off as it is the cause of my leg problems right now! |
| May 29, 2025 at 6:00 pm #17089438 | |
No, please do not yet disable the String Translation plugin. Make sure to translate the Woodmart Layouts and let me know if the issue persists. |
| May 30, 2025 at 8:51 am #17091141 | |
milijanM |
I was able to access the Layout translation but I was not able to translate everything from one page. It would be good if you try to translate one whole page and record the process and send it to me because this is torture for both of us. I suggest you try this page hidden link |
| May 30, 2025 at 3:17 pm #17092708 | |
Your site does not have enough credits to run automatic translation and I am sorry to disappoint you, but our support can not create translations for you. Until now not any of your products have been translated to 100%. The translations will need to be completed to 100% when translating for the first time to be able to see the product in a second language. You do currently see the original product in a second language, as someone has set the "Products" in WPML > Settings > Post Type Translation to "Translatable use translation if available or fallback to default language". If you set this setting to "Translatable only show translated items" you will only see products in a second language if they have been translated. |
| May 31, 2025 at 5:28 am #17093711 | |
milijanM |
I don't know if you noticed, but you probably haven't, one product consists of the Layout and the other part of the product itself. So, Layout (photo with product name, Add to Cart button and Breadcrumb) The second part is the product itself, which contains a more detailed description, etc. I am not able to translate the Layout completely, the elements (Breadcrumbs, product name and everything else that I marked in red) What you are telling me has nothing to do with these things that I cannot translate! My question to you, can you help me to translate the things I mentioned or not? If you can't pass my ticket on to someone who can and wants to help. |
| May 31, 2025 at 3:51 pm #17094443 | |
My apologies for the misunderstanding, as it seems my prior message was not explaining the situation in detail enough. You were reporting issues with product translations while not having one translated product on the site yet. Your current settings display original products in second languages as long a translation does not exist: I see today that you have now translated one product: Issues here: - The product image can be replaced by uploading an alternative image with English text at WPML > Media Translation: - The Shipping and Delivery Tab is not translated, but as you created the translation with the WordPress Editor you will need to adjust this text directly inside Elementor on the English product: |
| June 2, 2025 at 8:30 am #17096877 | |
milijanM |
To be honest, I am very disappointed with both the plugin and your support. I have absolutely no idea what you're talking about and I can't believe you or anyone else has a problem helping me translate Breadcrumbs, product categories, and more. I followed the first part of the instructions you sent me through this link https://wpml.org/documentation/translating-your-contents/displaying-untranslated-content-on-pages-in-secondary-languages/#fallback-content and now everything is mixed up, what is in Serbian is English and vice versa! If you can't resolve this I request to speak to someone higher up in support, after all this is a paid plugin and I request help translating the rest of the product! I don't care how you will do it and who will do it, if you have a problem send the ticket to Noman! When I sent you the previous message, you did not explain to me at all how to translate the options that I get through a separate plugin and which are an integral part of the Add to Cart button. You completely ignored that! |
