This topic contains 31 replies, has 2 voices.
Last updated by Mike 4 years, 5 months ago.
Assisted by: Bruno Kos.
April 2, 2020 at 4:57 am #5819235 | |
Bruno Kos Supporter
Languages: English (English ) German (Deutsch ) French (Français ) Timezone: Europe/Zagreb (GMT+02:00) |
Hi, hidden link No matter how hard I try, still nothing, can you break it (don't unlink them as translation though) and tell me which action at which point did it? Regards, |
April 2, 2020 at 12:16 pm #5822261 | |
Mike |
Couple easy ways to break it. On the French page, try removing the pictures and click update. The pictures remain. Next, remove the Page Link Cards block. Add a blank Page Link Cards block, then click update. The English version appears with the text and pictures. |
April 2, 2020 at 1:04 pm #5822967 | |
Bruno Kos Supporter
Hi, Can you perhaps do this? We need nothing else - no other plugins, theme, content, nothing. That will tell us whether there is something wrong on your site or the set of these fields. Regards, |
April 3, 2020 at 1:20 pm #5832353 | |
Mike |
Great idea. However, having issues when trying to login ... says "ERROR: User can't find." |
April 6, 2020 at 5:08 am #5844379 | |
Bruno Kos Supporter
Hi, Can you try with these? mikeT-12 Regards, |
April 6, 2020 at 4:15 pm #5850739 | |
Mike |
Perfect, thanks Bruno! Those credentials worked. I'm not sure when my vendor will be able to install ACF Pro, but they advised me it'll be early this week. Will get back to you once it's installed and I've tested everything. |
April 7, 2020 at 6:21 am #5853849 | |
Bruno Kos Supporter
Hi, Ok, sounds like a plan, keep me posted. Regards, |
April 9, 2020 at 6:32 pm #5878901 | |
Mike |
Hey Bruno, so sorry for the delay on this. So I created a test page in English, but it's gave me the gears icon (instead of the + icon) when trying to translate. That doesn't happen on our site, it's always straight into the edit page without having to go through that gear icon. I turned off the Use WPML Translation Editor button from the right, but that didn't help. So I just clicked copy/all, saved, and then went into editing the page. Everything seems to work perfectly over there - no issues at all. I was able to update/move/delete, nothing broke - assume that's a good thing. 🙂 Wondering if the gears icon means anything in this situation? If not, what does it mean that everything functions correctly? |
April 10, 2020 at 6:44 am #5881353 | |
Bruno Kos Supporter
Hi, Gears icon only means that the translation is in progress, like it started but you have not completed it to 100%: But since you say it works, then it could be any of the following: Can I ask you the following? In order to debug this issue, I will install Duplicator plugin, will create packages and will try this on my localhost and possibly escalate further to 2nd tier. https://wpml.org/faq/provide-supporters-copy-site/ Let me know if this is OK with you. Regards, |
April 13, 2020 at 2:34 pm #5897055 | |
Mike |
Yes, this is fine ... please go ahead and install. Thanks!! |
April 14, 2020 at 6:00 am #5901071 | |
Bruno Kos Supporter
Hi, I restored the site to my localhost and am trying to break these two pages, but I guess I am bad with breaking stuff 🙂 hidden link Can you perhaps record a screencast with audio and show/explain how can I do it myself on my localhost installation? I am trying this - https://wpml.org/forums/topic/issue-syncing-english-and-french-pages/page/2/#post-5822261 - but to no avail, maybe I am look at the wrong things. Regards, |
April 21, 2020 at 6:28 pm #5962511 | |
Mike |
Sorry for the late reply on this, was on vacation for the past week. Hope you're staying safe and healthy. On your pages, see here for the video (the pictures won't change, even after deleting the block): hidden link For the 60th one page, the blocks go blank (see the second video). Sometimes the words won't change or go English, sometimes the pictures don't update, sometimes it deletes everything that's added, sometimes the links don't update ... it's random on what happens, but it only happens with that particular block. And it only messes up the last block on the page ... if there are 3 blocks, it'll mess up the 3rd one. If there's 1, it messes up that one. But the others all remain intact. |
April 22, 2020 at 7:03 am #5965105 | |
Bruno Kos Supporter
Hi, On your pages, see here for the video (the pictures won't change, even after deleting the block): But when I check hidden link, link_image, it has "Translation preferences" set as Copy, so it would be expected that on translated page - hidden link - that is, it would always sync with original and cannot be changed on translation. |
April 23, 2020 at 2:31 pm #5978203 | |
Mike |
Bruno, you amazing man. I think you figured it out. 🙂 I've personally never been on that page before (the vendor set up everything in there). I changed all of the page link cards fields to "Do not translate" and tested ... it didn't work. Then changed them over to "copy once", and it worked like a charm. I copied the entire live site back over to staging, changed them to "copy once" immediately, but it didn't work. So I tried the same thing again - do not translate, then copy once, and it worked. Went to the live site ... changed do not translate, saved, changed to copy once, saved - and lo and behold, everything works perfectly now! I can't thank you enough for your assistance on this - so thankful that you were able to figure it all out!! |
April 24, 2020 at 6:48 am #5983313 | |
Bruno Kos Supporter
Hi, So it means we got it resolved finally? 🙂 I believe that all this time I was misguided when you were saying that the original language gets wiped out completely. Translation preferences would not do this, so I wasn't sure what we were looking for and where the issue could have been. Regards, |
