You are working on a live shop and have noticed that the original Dutch product descriptions are not visible, although they appear when translated.
We have reviewed your issue and determined that the visibility problem with the Dutch product descriptions is not caused by WPML. This suggests that the issue might be related to the settings or configurations within your site's default language or possibly another plugin affecting the visibility. We recommend checking the settings for the default language and reviewing any other plugins that might interfere with the display of product descriptions. If the problem persists, please visit our support forum and open a new ticket for further assistance: WPML Support Forum.
Please note that this solution might be outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins.
Last updated by Itamar 2 months ago.
Assisted by: Itamar.
November 4, 2024 at 3:02 pm #16361725
erwinV-21
im working on the live shop
The original Dutch product descriptions are not visible anymore, but they appear when translated.
how can I fix this?
November 4, 2024 at 5:16 pm #16362688
Itamar
You have many of our plugins active without a need. Some of them are glue plugins to plugins that are not installed on your site, and some of them extend WPML, but you probably don't need them. Please consider deactivating the following plugins.
WPML SEO
Advanced Custom Fields Multilingual
Contact Form 7 Multilingual
WPML All Import
WPML ElasticPress
WPML CMS Nav
WPML ElasticPress
WPML GraphQL
WPML Export and Import
Ninja Forms Multilingual
WPML Sticky Links
We want to know why there was a fatal error when deactivating our core plugin, WPML Multilingual CMS.
Please share WordPress's debug log (not WPML debug information). Please check this page for instructions.
To enable it, open your wp-config.php file and look for
define('WP_DEBUG', false);
Change it to:
define('WP_DEBUG', true);
define('WP_DEBUG_LOG', true);
define('WP_DEBUG_DISPLAY', false);
@ini_set('display_errors', 0);
After this, repeat the action that causes the problem on your site. Deactivate WPML Multilingual CMS plugin. The errors will be saved to a debug.log log file inside the /wp-content/ directory. Then please share the errors with us.
Itamar.
November 7, 2024 at 1:58 pm #16377909
Itamar
Important!
Our forum is public. It is not a private discussion/thread only between you and us. So please refrain from posting sensitive information in public replies. I have removed the login details from the previous reply. For your site's safety, please change those details. I'm not allowed to use the access details as you shared them. You must share them in a private reply. This way, you also consent that we will access your site and that you have a backup.
Privacy and Security Policy
**IMPORTANT**
Itamar.
November 7, 2024 at 3:08 pm #16378457
erwinV-21
Hosting is relocating server now, please dont make any changes till tomorrow morning
November 7, 2024 at 3:12 pm #16378463
Itamar
OK.
I just logged in, but I'll wait for your reply.
Please remember that the problem is in Dutch, the site's default language. As far as I can tell, it is not an issue caused by WPML.
Please note that my weekend is Friday-Saturday, and I'll be able to continue to check this issue and help you on Sunday.
Itamar.
