This topic is split from https://wpml.org/forums/topic/wpml-not-translate-2/
Last updated by poonyalidP 1 year, 5 months ago.
Assisted by: Long Nguyen.
March 30, 2023 at 2:14 am #13363001 | |
poonyalidP Site owner |
Hi, Today I increase more CPU x 4 cores and RAM x 4 GB to the server. I found that the blank page problem is gone. I can load all WPML multilingual page. But I found this error. Please see illustrated. Also the pending translating job there. Seem waiting and not auto translate. I have not run the troubleshooting yet. I found more problem for some products. When I edit a product in Thai, it says this is the duplicate of Eng and have key locked. It also show that you are editing this product which is in the auto translate process.... something like that. Really confuse. Please help check. |
March 30, 2023 at 2:21 am #13363005 | |
Long Nguyen Supporter
Languages: English (English ) Timezone: Asia/Ho_Chi_Minh (GMT+07:00) |
Hi there, Thank you for contacting WPML support, I'd be happy to help you with this issue. In this ticket, we can focus on the issue with the WPML > Translations page does not display jobs. While checking the debug info, I see the Rest API is disabled on your site, please check this screenshot hidden link Some WPML features rely on Rest API so if it is disabled, they will not work properly. Please enable the Rest API on your site and check this issue again. If you don't know how to do that, please contact your hosting support to ask for help with this issue. Look forward to your reply. |
March 31, 2023 at 5:28 am #13372085 | |
Hi, I still waiting for my Plesk support to help how to enable REST API. I'm owner of my hosting server. If you can help providing instruction how to enable it, it would be great. Now the problem is the WPML is not translate,,,,.. scheduling to translate but nothing translate..... everything stuck. When enter Translation queue, these error are related to REST API disable? Error = "The Advanced Editor jobs synchronization has failed", "Jobs could not be loaded" Please see attachment error. Before this, while REST API disabled, the auto translation still working. Thanks. |
March 31, 2023 at 8:10 am #13373077 | |
Hi, Thank you for your feedback. >> When enter Translation queue, these error are related to REST API disable? Look forward to your reply. |
April 4, 2023 at 4:32 pm #13402593 | |
Hi, Plesk support system change new login system and had lots of problem. I just now reconnect to the Plesk support to open support ticket for enable Rest API. Please allow me some times for Plesk support to give me instruction how to enable it. Thanks. |
April 4, 2023 at 4:50 pm #13402713 | |
Hi, Plesk support test my server and found that the REST API is running properly at my server. Also the error might be false positive. Please see their reply in the illustrated attachments. Please advice what to do next? Thank you very much. |
April 5, 2023 at 2:51 am #13405289 | |
Hi, Thank you for your feedback. Can you please create a backup of your site and share the file with me? I will try to restore your site on the local host and investigate the issue further. You can use this plugin to create the backup: https://wordpress.org/plugins/duplicator/ Your next reply is set to private to share the info. Look forward to your reply. |
April 7, 2023 at 2:23 am #13424209 | |
Hi, Thank you for your feedback. I've restored your site on my local host and checked the issue. After enabling the debug log, I there is an error with the plugin NitroPack [07-Apr-2023 02:14:49 UTC] PHP Fatal error: Uncaught Error: Call to a member function get() on null in /Applications/MAMP/htdocs/butterflythailand/wp-content/plugins/__nitropack__/classes/Integration/Plugin/WCML.php:70 Stack trace: #0 /Applications/MAMP/htdocs/butterflythailand/wp-includes/class-wp-hook.php(308): NitroPack\Integration\Plugin\WCML->wcml_set_custom_language_cookie('') Then I deactivate this plugin and go to WPML > Translations, the jobs are displayed as well. On your site, please try to deactivate this plugin and see if it helps. Look forward to your reply. |
April 8, 2023 at 12:37 pm #13431313 | |
Hi, Nitropack support send me new hotfix update and not the WPML translation jobs are showing. But when I click the "Review", the error page occurred. Please help. Thanks. |
April 10, 2023 at 2:43 am #13435239 | |
Hi, Thank you for your feedback. I do not see that issue on the local host and your site when reviewing a job, please check these screenshots If you experience this issue again, I suggest you can try to clear the cache of NitroPack or deactivate this plugin for a while and review all translations then activate it again. Look forward to your reply. |
April 12, 2023 at 5:55 am #13452083 | |
Hi, Seems everything work perfectly. I have more question about disable auto traslation. I'll create another ticket. Thanks. |
