Last updated by Yulia Krzeminska 1 year, 10 months ago.
Assisted by: Yvette.
June 17, 2022 at 11:49 am #11484937 | |
Yulia Krzeminska |
Hello. hidden link |
June 17, 2022 at 2:36 pm #11486139 | |
Yvette Supporter
Languages: English (English ) Spanish (Español ) Timezone: Europe/Paris (GMT+02:00) |
Hello I will be helping you. The message is a warning to set a WCML configuration in a certain way. For the other issue: Temporary access to your system Could you please provide access to your system (wp-admin and ftp) so that I can further investigate this particular problem? The fields to provide this data are included in a private section that I will open for your next response. You can find it above the comments area. The information in this private section is only visible between WPML Support and you. |
June 17, 2022 at 4:14 pm #11486623 | |
Yulia Krzeminska |
Hi! Sorry, but I can't send you information for FTP access. I can create screenshot for you with needed information, or try to do your instractions. |
June 20, 2022 at 8:01 am #11496417 | |
Yvette Supporter
I don't need FTP access but I would need to see the WordPress dashboard. I that cannot be done, please send us a copy of your site as per this article. You can use WeTransfer to send us a downloadable link to the Duplicator package in your next reply. https://wpml.org/faq/provide-supporters-copy-site/ Thanks |
June 21, 2022 at 3:47 pm #11511845 | |
Yulia Krzeminska |
Hello Thank you for your response. I managed to find myself in the cause. The work in this translation product does not synchronize the designation of the field "Form location" from the main language. By default "Default", in the previous product "Before tabs". How can the synchronization of the this field be included? |
June 21, 2022 at 4:05 pm #11512021 | |
Yvette Supporter
OK. These should be held in custom fields. The easiest way to see which ones they might be is as follows: - go to WPML > Settings >Custom field translation - see if you can find the custom fields that represent the information that you are trying to sync to the translations. (use the "inspect" of the browser of if you have a phpMyAdmin tool you can scan the post-meta table for this post-id) - Set the option to "copy" this custom field and choose "Apply" |
