You are trying to use WPML to auto-translate products on your site but are encountering issues because the auto translation with AI for products is not completing when you select products and click Auto translate. You are unsure how to register the credits to the live domain.
First, ensure that your domain is registered for automatic translation. It appears that you might have migrated from a different domain and did not set the options for automatic translation on the new domain. You should find a note about this under WPML -> Translation Management -> Tools. For more details on how to handle this situation, please visit Using Advanced Translation Editor when you move or use a copy of your site.
If this solution does not apply to your case, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If you still need assistance, please open a new support ticket at WPML support forum.
Last updated by 7 months, 4 weeks ago.
Assisted by: Itamar.
