Last updated by ToBulk 9 months, 2 weeks ago.
Assisted by: Osama Mersal.
July 15, 2023 at 9:36 am #14042197 | |
ToBulk |
Hello, I have a very strange problem that I cannot solve on my own. In all blog posts, everything is as it should be in English (the main language). In the two translations (Spanish and German) the layout shifts a few pixels to the right. See the pictures. What is the cause here? Best regards Torsten |
July 16, 2023 at 10:12 am #14043989 | |
Osama Mersal Supporter
Languages: English (English ) Arabic (العربية ) Timezone: Africa/Cairo (GMT+03:00) |
Hi Torsten, Thanks for contacting WPML forums support. I'll be glad to help you today. Please let me know if you use a custom template for blog posts. Also, please check if the CSS is the same in all languages. Best regards, |
July 16, 2023 at 10:16 am #14043997 | |
ToBulk |
Hi Osama, thank you for your answer. The css of the theme and also the custom css is the same for all languages. Also the template for the post formats. But it seems that WPML is ignoring something. Best regards Torsten |
July 16, 2023 at 10:44 am #14044099 | |
Hi Torsten, I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP) Your next answer will be private, which means only you and I can access it. ❌ Please backup your database and website ❌ ✙ I would need your permission to de-activate and re-activate the Plugins and the Theme and change configurations on the site. This is also a reason the backup is critical. ✙ I also need your permission to take a local copy of your site to debug the issue without affecting your live site. Best regards, |
July 16, 2023 at 11:20 am #14044197 | |
Hi, Please check the access details because I got the following error. (Error: The username **** is not registered on this site. If you are unsure of your username, try your email address instead.) Best regards, |
July 16, 2023 at 11:23 am #14044199 | |
ToBulk |
Sorry, a misspelling |
July 16, 2023 at 11:41 am #14044221 | |
Hi, Thanks for the access details. I checked the issue and found a margin-left added to the translated posts, and it's not added to the default language. (Kindly check this hidden link) Please remove this margin from your custom CSS and check the issue. Best regards, |
July 16, 2023 at 3:11 pm #14045161 | |
ToBulk |
Hello Osama, thank you for your look and your observation. So it's not the fault of wpml. I have already corrected this. Thank you for your support. Best regards Torsten |
July 16, 2023 at 3:13 pm #14045165 | |
ToBulk |
I am always happy that I have chosen wpml. |
