Our next available supporter will start replying to tickets in about 1.04 hours from now. Thank you for your understanding.
This topic contains 9 replies, has 3 voices.
Last updated by Bigul 1 year, 7 months ago.
Assisted by: Bigul.
September 20, 2022 at 10:04 pm #12090159
jonathanS-28
I'm editing a LearnDash course on a site that is set to manually use WPML for translation and I'm getting a persistent error that the course is being translated and that there's a problem. See screenshot.
September 22, 2022 at 10:38 am #12103105
Bigul
It looks like this warning is showing because the translation job is existing for this Course post in WPML Advanced Translation Editor. So please try the following steps after a full site backup{mandatory} and make sure the issue is existing or not.
1) Visit WPML>>Translation Management>>Jobs
2) Search for the Course Post by title
3) Cancel the existing translation job
4) Open the Course Post for editing in the original language(The one showing notice)
5) Make sure the WPML Editor option is disabled for it - https://wpml.org/documentation/translating-your-contents/using-different-translation-editors-for-different-pages/#how-to-use-manual-translation
6) Make a minor change in the content & update the post
7) Update the translation
Bigul
September 22, 2022 at 7:56 pm #12106619
jonathanS-28
Thank you, but when I view the Translation Management page it is blank and displays nothing but the nag asking whether the site has been moved or copied.
September 23, 2022 at 7:35 am #12108807
Bigul
Thank you for the updates. Have you changed the Site URL or migrated the site recently?
Please try the following steps after a full site backup{strong} and make sure it works as expected or not. Refer to this documentation for more details - https://wpml.org/faq/install-wpml/#register
1) Visit WPML.org>>My Accounts>>Sites - https://wpml.org/account/sites/
2) Delete the existing site key
3) Then create a new subscription key for the site
4) Visit the Site Dashboard and go to Plugins>>Add New>>Commercial
5) Click on the *Unregister WPML from this site* button
6) Register with the new site key and refresh the page
Bigul
September 27, 2022 at 2:55 pm #12133175
jonathanS-28
To clarify: this is on a two-site multisite install. The sites each have WPML activated individually because there was an issue with network-activating them. The subsite has the main site's activation key enabled and I've not been able to switch that to its own key even though one exists in the WPML account dashboard. Should I remove the key from both sites and try to add them individually back?
New threads created by Bigul and linked to this one are listed below:
https://wpml.org/forums/topic/activate-wpml-site-key-in-a-multisite/
September 27, 2022 at 5:37 pm #12134631
Bigul
Thank you for the updates. Hope you are using different URLs for the main and subsite.
Please fill the private details fields after a full site backup. I would like to access the network admin area of your site(because of multisite installation) for further checking. Refer to the following links for more details about our private information sharing policies.
Bigul
September 29, 2022 at 7:34 am #12146493
Bigul
Thank you for the details and login information. I have created a new ticket for the *WPML Site Key in a Multisite* issue. Because as per our support policies, we can only handle one issue per ticket. It will help us to serve you better and we can avoid discussing multiple problems in one ticket. Also, it will help other users with similar problems find solutions when searching the forum. I will get back to you soon on the latest ticket. Please wait. Thank you for your understanding.
Bigul
October 6, 2022 at 10:38 am #12192687
ericS-17
Wrong user. Please delete this reply.
October 6, 2022 at 10:40 am #12192693
jonathanS-28
Writing this to keep the ticket open as it is not resolved.
October 6, 2022 at 2:43 pm #12194961
Bigul
Thank you for the updates. Please ignore the notifications. This ticket will not be marked as closed until the sub-ticket is finished.
Bigul
The topic ‘[Closed] Error references automatic translation problem but the site is not set for auto’ is closed to new replies.
